Location of dome light and parking light wires (alarm install)
Old Sep 18, 2004 | 07:54 AM
R92max's Avatar
Putting in a new alarm in my 92SE. Found all the wires I need so far with some help from a wiring diagram, except the dome light and parking light. Is the dome light wire located on the factory alarm box? I'm sure the parking light wire can be tapped into from behind the hazard switch, but is there anywhere else better?
Old Sep 18, 2004 | 08:24 AM
rrrfoma's Avatar
SEARCH BEFORE POSTING!!! :
<from the12volt.com>:
Alarm
Constant 12 volts WHITE/RED OR WHITE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/WHITE OR WHITE/GREEN - IGNITION SWITCH HARNESS
Starter BLACK/YELLOW OR WHITE/BLUE - IGNITION SWITCH HARNESS
Dome Light ORANGE/BLACK (-) DRIVER KICK PANEL *
Trunk Pin Switch PINK/BLACK (-) DRIVER KICK PANEL *
Parking Lamp RED/YELLOW (+) HEADLIGHT SWITCH OR STEERING COL HARN
Power Lock GRAY/RED DRIVER KICK PANEL OR AT DOORLOCK
Power Unlock LIGHT BLUE TIMER TO RIGHT OF STEERING COL.**#201
#201- See Negative Pulse Door Lock Diagram. * Also Found At Theft Warning Module To The Left Of Steering Column ** From Installer:Wires Are Found In Large Harness In Kick Panel.
Remote Start
Tach Signal GREEN/BLACK/SILVER 2ND OF 4 CONNECTORS AT ECCS, PIN 7 *
Ignition #2 N/A
Ignition #3 N/A
Accessory WHITE/RED IGNITION SWITCH HARNESS
Neutral Safety NOT GROUNDING TYPE - O.E.M. SWITCH OPENS STARTER CIRCUIT
Brake Light RED/WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light RED/BLACK (+) AT GEAR SELECT SWITCH ON TRANSMISSION
Rear Window Defrost N/A
* Electronic Concentrated Control System (ECCS) Module Located Above Gas Pedal, Behind Console. Tach Wire Sometimes Found As BLUE At Pin #7 At ECCS. Cold Start Wire- GREEN/RED Or BLACK/GREEN At Ignition Switch Harness.
Old Sep 18, 2004 | 09:53 AM
R92max's Avatar
Appreciate your effort there, but I've got all that already. I hate when they put some lazy undetailed description like "driver side kick panel." I'm asking specific question here.
vingodine
45
May 21, 2016 12:46 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
Samedi
Aug 13, 2015 04:05 PM
King_Ten_Ahead
Aug 13, 2015 09:46 AM
