advice on locks
Old Sep 21, 2004 | 08:30 AM
ronal404's Avatar
advice on locks
1989 SE- I broke the key in the driver side door and the broken piece is lost somewhere in the lock. I cannot see it but can feel it when I put another key in. There is nothing to grab onto with needle nose pliers.
Is there any way to get the lock apart or do I need to buy a new lock?
Old Sep 21, 2004 | 09:25 AM
internetautomar's Avatar
mod or sell?
big ole magnet!!
Old Sep 21, 2004 | 09:27 AM
Jeff92se's Avatar
I'm needing a caw
Want to explain that a bit???
big ole magnet!!
Old Sep 21, 2004 | 09:53 AM
mod or sell?
your key is metal, magnets attract metal, a powerful enough magnet will pull the key out of the lock.
Any other questions?
Old Sep 21, 2004 | 10:15 AM
Jeff92se's Avatar
I'm needing a caw
Where is he going to get one?? Exactly where??? Do you sell them??
Old Sep 21, 2004 | 10:54 AM
mod or sell?
it's called a battery , some wire and a nail.
Remeber that 2nd grade science project
Old Sep 21, 2004 | 10:55 AM
Jeff92se's Avatar
I'm needing a caw
So you tried it??
Old Sep 21, 2004 | 11:09 AM
mod or sell?
professional locksmiths do it with a slightly more high tech version of the device.
I've never had need to do it than g-d
i'm normally missing the key entirely!
in principal it should work with magnetizing the key itself (assuming he can get enough windings around it)
Old Sep 21, 2004 | 11:15 AM
Jeff92se's Avatar
I'm needing a caw
Thank you. This is better than "big o'le magnet" that your first reply had. Please try to be more descriptive in the future. (VS being criptic and generally like Shawn posts) This is NOT Maxworld here.
Old Sep 21, 2004 | 11:34 AM
mod or sell?
You got a problem with max-world bub?
I like being cryptic, it encourages people to think. Too many people want every answer handed to them and then they'll question it because they don't like the answer.
A big ole honkin magnet will still work it's just a much bigger pain to use.
I used to play with them at radio shack alot, that and the remote control cars on that big slab of slick tile in between the us and the other side of the mall.
Old Sep 21, 2004 | 11:36 AM
Jeff92se's Avatar
I'm needing a caw
No I don't have a problem with maxworld. You what you will on there. But just don't bring the whoring here. ***** up MW all you want.
Old Sep 21, 2004 | 11:39 AM
MrGone's Avatar
do you by chance have one of these?
Some people forget they have them
Old Sep 21, 2004 | 11:42 AM
mod or sell?
that card won't help a key broken in the lock though, they'll unlock the car, but not neccesarily remove the key.
I have nextel's roadside anyhow, better coverage. Includes free gas :P
Old Sep 21, 2004 | 11:43 AM
mod or sell?
bring here what was already here, there it just goes OT all the time even in OT, no thread remains true to it's origins for long :muwhaha:
Old Sep 21, 2004 | 11:48 AM
Jeff92se's Avatar
I'm needing a caw
So that means you should contribute to it??????? I have a hard enough time with the newbies. I don't need you and shawn adding to it. Makes sense?? Especially when I've overlooked you sales threads. Which I don't mind because of the nice deals you give people. But on that note, I hold you to a higher level than others here also. Again, makes sense?
Old Sep 21, 2004 | 12:00 PM
mod or sell?
oh, cmon my whoring is rarely that bad here.
Yeah some of the newbies are a pain, ok most of em are.
I know I get held to a higher level, and by the same extension I know I get more slack because of the mutual respect.
and we really should take this to PM
Old Sep 21, 2004 | 12:31 PM
DanNY's Avatar
Ad·min·is·tra·tor
well make sure you have another key around...spare?
take off the inner door panel...then reach under the plastic and unbolt the door handle. there should be 1 spring clip (plastic) to undo and 2 10mm nuts...maybe 2 wires...(i'm thinking SE here)
once that's done u can take the handle out and you can probably see the lock cyl. take a paper clip or a metal pick and push the broken bit from the back. you MIGHT need to prop open the shutter/door and the key SHOULD pop out. if that doesn't work you might have to take the cyl off the handle...and then pop it out. get some WD40 in there to make sure everything moves smoothly.
bolt it back up..get some lube in there and you should be good.
Old Sep 21, 2004 | 07:16 PM
bhunter's Avatar
Kids!!! Settle Down!!
OK, Technically I'm a newbie to this forum---but I'm old enough to be most of your Fathers. JUST TRY picking up a key with a magnet!!! Magnets are attracted to IRON. Iron is in steel. Most keys are mostly brass. Try picking out the partial key with a dental pick. Geeezzzz--kids.
Mahmuth
Aug 16, 2024 08:23 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
