What's in your manual tranny?
Old Sep 25, 2004 | 04:32 PM
Coochie Coach's Avatar
I cracked open the drain plug on the manual transaxle on my '93 SE and found it full of that red automatic transmission stuff. I know that's spec for the manual transmission of a Ford pickup I have, and maybe it's fine for the Maxima, too. Dunno.
Do you guys run the red stuff or use more traditional gear lube?
Old Sep 25, 2004 | 04:45 PM
Mizeree_X's Avatar
Getting back to his roots
I'd run gear lube -- ATF seems a bit thin to properly protect the moving parts. MT-90 is a good synthetic gear lube that people here use.
Old Sep 25, 2004 | 05:43 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
ATF in a manual ?? stick with redline mt-90 you'll like it.....
Old Sep 25, 2004 | 08:53 PM
ntjoe's Avatar
I had an old Talon that someone ran that in. I changed it as soon as I got it, but it already had a syncro grinding. Best to get it out now and go with the suggestions you have. Redline is really good.
Good Luck! Joe
Old Sep 25, 2004 | 08:54 PM
Bman's Avatar
Are you sure it's not just red transmission oil and you are sure it really is ATF?
MT-90 is red I think... (can't remember what it looked like anymore).
The stuff that drained out of it was golden/green.
Old Sep 25, 2004 | 08:55 PM
Mizeree_X's Avatar
Its more of a light pink.
Old Sep 25, 2004 | 09:31 PM
MrGone's Avatar
I thought MT-90 was tan? hmmmm
anywho mines green
Old Sep 25, 2004 | 10:35 PM
mtcookson's Avatar
purple gear oil here. i've heard of people running atf if a manual tranny but that scares the hell out of me. i hear redline mtl is supposed to be thin like the atf but properly protect and lube the gears. its also available in gl-4.
Old Sep 26, 2004 | 04:17 AM
nubiannupe's Avatar
OG Maxima.org Member
So, I guess black fluid in my gear box is a BAD thing, huh?
(disclaimer - I'm just joking, btw... I'm running redline! )
Old Sep 26, 2004 | 05:08 AM
MrGone's Avatar
I thought you were auto :wtfmate:
Thats alot of mula$$$
Old Sep 26, 2004 | 12:37 PM
KLoWnPR109's Avatar
My redline was a tannish/brown color IIRC
Old Sep 26, 2004 | 02:01 PM
3rdgenmaxima's Avatar
I use Royal Purple i believe it said it is compatable with Gl-4 and Gl-5. Not sure but my maxima loves this stuff. When i change my gears i noticed a much smoother gear shift. My rpms seems to be a little better too like it picks up fast but this may be in my head. THis stuff is like a thick purple goop and is like 8 bucks a bottle. I definately reccomend this stuff for your tranny
Old Sep 26, 2004 | 04:51 PM
wolfpack_5150's Avatar
Apple Pie Monster
Yeah purple is safe to use instead of GL4. GL5 eats synchros in nissan trannys cause it has twice as much extreme pressure additive in it than GL4. Purple is expensive but its good shiot and cheaper than a rebuild.
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
