Motor won't start can somebody help me out please
Old Sep 28, 2004 | 10:13 PM
nadda20xl's Avatar
hey my fello maxima's i had a bad water pump problem, n i replace w/ a new on e. while replaceing it ineed to take out da pulley had to change the timeing belt. now when i put every thing back to gether the car won't start. do any body have idea y it won't start ?
ps... 90 max auto
Old Sep 28, 2004 | 10:46 PM
fastflyingasian's Avatar
were the timing belt pulleys in the correct position when you put it all back together?? if not.... then you could be fubar'd. if the pulleys were not in the correct position then the car defenitly wouldnt run right if at all.
Old Sep 29, 2004 | 06:34 AM
ntjoe's Avatar
Had to read that twice...ouch my head hurts.
Sounds like you got your timing off when you replaced the T-Belt. Do you have a Service Manual or Haynes book? You probably need to take the belt off, line up all the timing marks as the manual says, and then put it back on.
Good Luck, Joe
Old Sep 29, 2004 | 06:52 AM
nadda20xl's Avatar
i tryed line every thing up n when i try to start the car every turn but it won't start
Old Sep 29, 2004 | 06:55 AM
nadda20xl's Avatar
do any body know where i can get a manual
Old Sep 29, 2004 | 07:37 AM
ntjoe's Avatar
You can get a haynes manual at pretty much any auto parts store. The FSM (Factory Service Manual) I'm not sure, but I know some people here have them, you might can get someone to scan those instructions to you.
Is it just not firing? Or are you getting a misfire? Have you checked your basics (spark, gas, etc)? Did you check to see if something got unhooked by accident or something didnt get hooked back up?
I know thats all basics, but sometimes it could be something small.
Good Luck!
Old Sep 29, 2004 | 10:17 AM
broncoguy's Avatar
That question was probably best asked BEFORE you started to work on the car.
When the car runs before you work on something, and it doesn't run after you are done, it's a pretty good bet that it has something to do with what you just did...
So, like these folks said, I'd be willing to bet you have the timing off. Did you set the correct cylinder to TDC before you took it apart? With these engines, you really need to be careful about the timing, since you don't want valves slapping pistons...
Old Sep 29, 2004 | 01:40 PM
nadda20xl's Avatar
it just not fireing
Old Sep 29, 2004 | 05:40 PM
broncoguy's Avatar
it just not fireing
And it won't, if the timing is off. Do you hear the fuel pump run when you first turn the key on?
Old Sep 29, 2004 | 07:15 PM
nadda20xl's Avatar
yea i do hear the fuel pump run
Old Sep 29, 2004 | 07:48 PM
broncoguy's Avatar
OK, so it's not a fuel problem, then. Back to timing, I'm afraid.
Old Sep 29, 2004 | 08:17 PM
drakken789's Avatar
wow, i came in here at the wrong time
Old Sep 30, 2004 | 07:46 AM
nadda20xl's Avatar
plaese some one help me this is my 2 feet n soul
Old Sep 30, 2004 | 08:33 AM
broncoguy's Avatar
Umm...we are trying to help you, but I haven't seen you posting back that you have tried ANY of the things that have been suggested. We can't solve the problem for you online, we can only give you suggestions as to what to look at. You have to check those things and then let us know so we can rule things out. Troubleshooting is a logical process of elimination, but you have to eliminate some things for it to work. If you don't want to take our advice, then have it towed to a mechanic and let them do it for you.
Bottom line is I think you have the car out of time, which means the only way to fix it is to go back and re-do what you have already done, and make sure everything is lined up as it should be. I can't GUARANTEE that's the problem, but since it ran before you changed the belt and it doesn't run now, LOGICALLY, it probably has something to do with the work that you just did on it.
Retrace your steps and look at everything you took off and put back on, and you'll probably find what's wrong. And PLEASE invest the $15 in a Haynes or Chiltons manual before you do anything else.
boomerbrian
Oct 31, 2018 10:25 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
