Problem 2
Old Oct 12, 2004 | 06:50 AM
ish's Avatar
ish
Problem 2
2) Got alternator, battery and battery cables replaced 2 weeks ago and when i put radio on after some driving i turn the car off and after that it wont turn back on. I have a Clarion unit with cd changer, pioneer premier speakers and a bazooka that is a preamped rs model. do i need one of those ghetto looking caps or should i get better amp wire so it wont pull too much power. I Need music!
Old Oct 12, 2004 | 06:57 AM
DanNY's Avatar
Ad·min·is·tra·tor
the radio is not coming back on or the car is not coming back on?
you have a heavy drain on the battery somewhere? perhaps the system was wired in incorrectly?
Old Oct 12, 2004 | 07:04 AM
ish's Avatar
ish
The radio often cuts on and off when driving and when the car turns off i wont be able to turn it on for a while
Old Oct 12, 2004 | 07:06 AM
DanNY's Avatar
Ad·min·is·tra·tor
you have a short...or a heavy drain on the battery.
take out the entire radio/audio system and make sure you connected the correct wires.
Old Oct 12, 2004 | 07:13 AM
Matt93SE's Avatar
STFU n00b!
install problem. pull the entire stereo out, pull the fuses out, then do it again properly. hope it doesn't catch fire between now and then.
bitter, no. honest, yes.
Old Oct 12, 2004 | 07:19 AM
DanNY's Avatar
Ad·min·is·tra·tor
get em' matt!
Old Oct 12, 2004 | 08:25 AM
ghostridden's Avatar
my friend had that problem, his was due to a fuse that kept blowing....everytime he opened the trunk with the switch it'd blow the fuse, lol, so he took out the button and just uses a key now....i told him that there was a way to fix it....
Old Oct 12, 2004 | 06:34 PM
ish's Avatar
ish
found problem. alternator installed not charging replaced with new one. lets see how that works. called clarion, when not enough power going to headunit or when not enough power being distributed in car . i automatically cuts off. but its all alternators fault. well see in a few days.
Old Oct 12, 2004 | 06:59 PM
nismo3366's Avatar
Ya i had the same problem, when buying a alternator sometimes it takes a couple of tries to get one thats not defective...make sure your battery wires are connected really tight...my car did the same thing after putting in a new alternator, the ground wire wasent on good enough, ended up blowing the alternator.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
