How to remove right axle?
Old Oct 20, 2004 | 12:21 PM
alpicone's Avatar
I am trying to remove the right axle (pass side). The left axle came out very easily but I am having a hard time getting the right side out. The FSM says to pry it out from the axle support. But I tried to pry it out carfully but I am bending part of the axle and the axle isnt budging.
Pics
If you look at the pics you can see what I am talking about. The are a couple of bolts on the axle support, do I have to remove these to get out the axle? If any of your experts got any tips I am ready to learn.
TIA
Old Oct 20, 2004 | 12:23 PM
Jeff92se's Avatar
I'm needing a caw
lol!!! Hint. Removing the 3 12mm bolts helps.
Old Oct 20, 2004 | 12:30 PM
alpicone's Avatar
Very nice of the FSM to leave this little tidbit of info out. On a Acura which I took out the tranny I didnt have to remove it so I didnt think I had to here. Guess I'm an idiot.
Old Oct 20, 2004 | 12:33 PM
Jeff92se's Avatar
I'm needing a caw
Live and learn that's all. As long as you don't damage it, you're okay. Take off those bolts and it should just yank out. Or pry as before. I'm pretty sure the FSM should mention this but I never use the FSM 90% of the time anyway. Or you could try the autozone manual in the stickies
Old Oct 20, 2004 | 12:35 PM
Jeff92se's Avatar
I'm needing a caw
http://www.autozone.com/servlet/UiBr...3d801f558b.jsp
If removing the right halfshaft, remove the bolts securing the support bearing.
Carefully pry the support bearing out of its housing. The support bearing will not fully slide out of its housing until the halfshaft is removed from the transaxle
Old Oct 20, 2004 | 12:57 PM
Jeff92se's Avatar
I'm needing a caw
BTW. Nice job with the pics. If not for those, it could have been difficult to advise what the problem was.
Old Oct 20, 2004 | 01:02 PM
alpicone's Avatar
Thanks man. A picture is definitely better than trying to describe the prob and then ppl trying to figure out what I'm talking about.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
