Widest tire on a 17inch rim wihtout scrubbing
Old Oct 24, 2004 | 08:10 PM
Kikcaffine's Avatar
What is the largest and most reccomended size tire for the maxima, in 17in size. I would not mind using spacers if needed to fit like a 235 tire on it.
Old Oct 24, 2004 | 08:19 PM
Maxininct's Avatar
Well alot of it depends on what the width therim is, and what ur gonna be doin with it, dont always need a wide tire, cause wide tire means more $.
Old Oct 24, 2004 | 08:21 PM
Kikcaffine's Avatar
So like a 225 45 would be good or a 225 50?
Old Oct 24, 2004 | 08:30 PM
Harvs94max's Avatar
i have set 235 45 17 and they fit great and i have another set a 215 50 17 and they also fit great no rubbs just depends on your rim offset and size
Old Oct 24, 2004 | 08:41 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
depends on the width and offset...
post specs then we can help
Old Oct 24, 2004 | 08:42 PM
Maxininct's Avatar
Yea i have a 225/45/17 set up no rubs at all, but i also have a very wide rim, so theres almost no room between the rim and my struts, but tire isnt close to rubin at all. I dont know if id go with a 50, 45 is just right.(to me)
Old Oct 26, 2004 | 04:52 PM
Tin's Avatar
Tin
ur 235's may not rub because you dropped ur car and changed ur struts. but when i put my 235's on with the stock struts, it definitely rubbed. i needed a spacer for the 2 rear tires. the front two tires still rub but only when i turn the wheel as much it can go to any side.
Old Oct 26, 2004 | 05:18 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
the struts/drop mainly w/ springs and struts isn't going to affect anything as long as the rim and tire size are right for the car. it all depends on the rim/tire size/offset. hence we want to know what the rim width and offset is
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Garrettz459
Sep 28, 2015 02:50 PM
