ABS relay stuck ...?
Did anybody happened to have an ABS relay be stuck before?
I'm not sure what it is ... I'm talking about a black box above ABS manifold (front right side).
I got ABS light on yesterday. The very same thing happened last winter, so I didn't pay much attention - planned to disconnect the battery which would reset computer and everything would be fine again ... so I thought.
Anyway ... when I got home in the evening and turned the key off, I still could hear a noise coming from the engine - similar to like some pump still was pumping something (sounds funny)
What helped is "kicking" this black box fro the top.
This morning everything was fine but this "noise" thing and "ABS light on" returned when I was driving from lunch. Kicking did help again but ... is there anything else wrong but a stuck relay? ... is this black box serviceable (I didn't open it yet)?
Thanks,
Alex
Thanks,
Alex
2 things:
1. My buddy just had the same problem on his J30 and it was the relay
2. Whereabouts in chicago you gonna be?
That's what I thought it is (a relay). I can live with that for a while.
Thanks for your help!
sorry to revive such as old old topic, but i didnt want to create a new one. It just cluter up everything!
I have the same exact problem..my ABS light is on, when i turn off the engine i hear the sound above my right side front wheel.
Where is the relay located? does anyone have a pic? or just an arrow pointing to where it is? i'll try to fix this problem 2morrow and buy the relay at auto barn.
Thanks bros
Thanks bros
ok i found a square black thing with a plug(wire) into it..i just pulled the wire out and the noise stop..is that the relay or is the relay located somewhere else? is it safe to drive around with it unplug?
can you give us a pic, or tell us exactly what is around it?
hi capedcadaver, hows it going my friend? Today i opened the relay box or whatever its called
. They were 2 relays, i pulled the first out and reinsert with no luck then the second relay which had a pointed top, then the noise stop and ABS light came off..so i cleaned the points out, it was alittle nasty. Everything is back to normal now!!!!
Sorry i couldnt take a pic for everyone...but i found this link via our forum
http://memimage.cardomain.net/member...7_107_full.jpg
. They were 2 relays, i pulled the first out and reinsert with no luck then the second relay which had a pointed top, then the noise stop and ABS light came off..so i cleaned the points out, it was alittle nasty. Everything is back to normal now!!!!Sorry i couldnt take a pic for everyone...but i found this link via our forum
tarun900
19
Dec 20, 2021 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
