Idle Problem
Old Oct 30, 2004 | 04:37 PM
ghostdawg's Avatar
Idle Problem
I have 89 SE 5 speed,the problem is such,when the car was cold it worked fine,when it got to normal temps it started idleing rough and bucking when reved up to 3 grand then it would start bucking at much lower rpms and the evenually shut off,when it cooled it would start back up,now its to the point where it wont start cranks fine,fuel pump is good,checked and saw that the spark from the coil was very weak,changed it still getting a weak spark,now im wondering if its the power transister ? plugs are good as well as wires & cap & rotor. Please maxima godz lemme know what else i should check
Old Oct 30, 2004 | 05:22 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
broken vacum lines, fuel filter, MAF, broken grounds, EGR
Old Oct 30, 2004 | 06:06 PM
internetautomar's Avatar
mod or sell?
if the spark is weak from the coil, i'd check to make sure the polarity on the coil is correct
Old Oct 30, 2004 | 06:12 PM
k-reg92's Avatar
maf likes to do that if its not any of the other recomended things could be your ignition module that also controls spark
Old Oct 30, 2004 | 06:33 PM
ghostdawg's Avatar
ok the infos great fellas thanx a lot,just 1 thing im a little green whats "MAF" ?
Old Oct 30, 2004 | 07:29 PM
mod or sell?
MAF = Mass Air Flow sensor.
Old Oct 30, 2004 | 07:45 PM
ghostdawg's Avatar
ok Thanx internetautomar
97_GXE
20
Sep 17, 2015 08:12 PM
lrb6805
Sep 17, 2015 04:49 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
