Still a bad idle problem need help
Old Oct 31, 2004 | 11:08 AM
Harvs94max's Avatar
I still have an idle problem with my ve i cleaned out the throttle body the egr valve and change oil and toyota filter and ran seafoam throught the vacum lines the idle seems to be fairly consistent now until you hit anything power like if i go to roll down my windows the idle drops below 500 and almost dies same if i turn on my headlights on or if i hit the brakes or if i turn on the air.
Any ideas? I am going to try and take it to advance auto parts and have the charging system tested but i donno it must be something electrical.
Old Oct 31, 2004 | 11:10 AM
portdave's Avatar
Did you clean the IACV? I just did this myself. Just pick up a new gasket for it.
Old Oct 31, 2004 | 11:24 AM
internetautomar's Avatar
mod or sell?
I'm betting your voltage regulator is having a problem. OR the belt is too loose on the alternator
Old Oct 31, 2004 | 11:54 AM
blacks92seAuto
where is the IACV and how do you clean it? and also, does anyone know how to adjust idle on ve automatic? ive looked in the manual and where it says there is a turn screw to adjust it, on my car there is a hose..
Old Oct 31, 2004 | 12:27 PM
Harvs94max's Avatar
well ill try cleaning the idle air control valve and the altenator belt is tight enough i adjusted it but where is the voltage regulator? and can i replace it?
Old Oct 31, 2004 | 01:46 PM
portdave's Avatar
The IACV is located just below the throttle body. It has 2 wire connectors attached to it. One is purple and one is brown. You need to remove 2 nuts and 2 bolts. You also have to pull off some coolant hoses. It is usually easier to see if you remove the flexible hose going to the TB first.
Once you get the nuts and bolts off you need to pull up on the hard tubing (has 4 i think hard lines for the fuel) that has the 2 top bolts going thru it and pull it out of the way to get the IACV off.
Some of the IACV units have a thumb screw and some have a phillips on it for adjustment. If you just want to try and adjust it you need a long phillips screwdriver. Look from the front of the engine under the TB and you will see it.
David
Old Oct 31, 2004 | 02:10 PM
mod or sell?
Voltage regulator is part of the alternator thought they can be replaced seperately
Old Oct 31, 2004 | 03:25 PM
HustleLikeM0FO's Avatar
I had the same problem on my old car which was a Monte Carlo...... your alternator seems to be going. On my old car this problem lasted for about 3-4 months until the alternator completley went and I needed to get a new one.
Good luck
Old Oct 31, 2004 | 03:43 PM
Harvs94max's Avatar
thats what i was figureing although i took the alternator off and had it tested and it was good but now im going to get it tested on the car and see if its weak.
Old Nov 1, 2004 | 09:15 AM
MerkMax's Avatar
check the pulley size on your alternator, when I replaced mine they gave me a option of what size pulley I wanted. If so get the smaller one.
captchaos
Mar 15, 2016 12:18 PM
bryants95max
Oct 2, 2015 12:52 PM
97_GXE
20
Sep 17, 2015 08:12 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
ballerchris510
Sep 10, 2015 09:35 PM
