17x8.5
Old Oct 31, 2004 | 08:41 PM
maxmvp's Avatar
17x8.5
Are 17x8.5 to wide of a wheel for an 89 maxima?
Old Oct 31, 2004 | 09:10 PM
dmontzsta's Avatar
Ford Only.
8.5 is pushing it, it all depends on the offset and rim style.
Old Oct 31, 2004 | 09:11 PM
Jeff92se's Avatar
I'm needing a caw
Maybe it is and maybe it's not.
Old Nov 1, 2004 | 07:38 AM
Kikcaffine's Avatar
Thats freaking enormous!
Old Nov 1, 2004 | 12:18 PM
wolfpack_5150's Avatar
Apple Pie Monster
Arent cobra rims 17x9?
Old Nov 1, 2004 | 12:30 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
as stated it completely depends on offset and style of the wheel
Old Nov 1, 2004 | 12:42 PM
ChrisCheezer's Avatar
im sure u can get huge spacers and make it work.. but thoes rims are "really" big! whats the off set on them?
Old Nov 1, 2004 | 12:44 PM
Jeff92se's Avatar
I'm needing a caw
Please explain how "huge spacers" will allow him to run 8.5" wide wheels.
Old Nov 1, 2004 | 01:07 PM
Kikcaffine's Avatar
why do you want to run something that wide for? expensive tires!
Old Nov 1, 2004 | 01:55 PM
Badaxxima's Avatar
Better Handling!! Seriously though, he's right. 17x8 with 35mm offset (is that right Jeff?) will hold a 235/45-17 tire. That's plenty for a Max.
Old Nov 1, 2004 | 03:40 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
this i would like to know
Old Nov 1, 2004 | 03:51 PM
anaximander's Avatar
17x8.
I have yet to see a max with an 8.5.
Old Nov 1, 2004 | 04:13 PM
dmontzsta's Avatar
Ford Only.
haha, thank you. I was just going to ask that.
...Can you say "Daytons?"
Old Nov 1, 2004 | 04:22 PM
Jeff92se's Avatar
I'm needing a caw
In 1998, the Cobra wheels were 17x8. But in the newer years, they started staggering them to 17x8.5" and started upping the diameter to 18".
Originally Posted by anaximander
17x8.
Old Nov 2, 2004 | 09:06 AM
Lordrandall's Avatar
I run 8" wide wheels with a 30 offset, no rubbing. 8.5" would fit for sure in the front, not sure about the back (depending on offset).
The only way to know for sure it to try and fit them on.
Pioneering is fun!
Old Nov 2, 2004 | 10:24 AM
-i thought i knew what i was talking about, guess not...
-only thinking about the rear, so they won't rub on the rear strut housing.. like mine did, if thats not because of the wider wheel, or different offset then why would they rub?
maxorg---> <----- me
Old Nov 2, 2004 | 10:25 AM
Jeff92se's Avatar
I'm needing a caw
Wide wheel + huge spacer = what does that do for the fender clearance? Think about it.
Old Nov 2, 2004 | 02:16 PM
OHHH! gotcha.. yay
Old Nov 2, 2004 | 05:57 PM
bonzelite's Avatar
think about unsprung weight. wheels of that size are more than likely heavy even if they did not rub.
Ludacris
Wheels/Tires
Mar 2, 2011 07:31 PM
MAXSE2kMT
Wheels/Tires
Jun 22, 2009 09:29 AM
michaelnyden
Wheels/Tires
Dec 15, 2008 09:00 AM
DoGGy
Tires and Wheels
Jun 2, 2006 05:30 AM
scopium
Tires and Wheels
Apr 13, 2004 06:18 PM
