300ZX Rims
Old Nov 1, 2004 | 01:26 PM
Duckman540i's Avatar
VE Powah!!!
300ZX Rims
Does anyone have pics of there Max with (Z32) 300ZX Rims on it? Also will I need to use spacers to put some '92 NA Z wheels on my car? Thanx For The Help
Old Nov 1, 2004 | 01:33 PM
MaximaSE96's Avatar
Maxima Owner
no spacers needed they dont look as good as Z31 wheels do
Old Nov 1, 2004 | 09:12 PM
Kikcaffine's Avatar
this has been asked a bunch of times, you need somehting like 5/8th spacers
Old Nov 1, 2004 | 11:13 PM
jwmaxse's Avatar
Are you joking?
Yes, you do need 1/2" or so spacers for the rear wheels only. If you have a half inch spacer you also need longer lugs and the setup can be expensive, I think only H&R makes them and they're at least $120.
And I don't know why anyone would put Z31 wheels on a max, not really worth it if you ask me.
Old Nov 2, 2004 | 08:25 AM
VE Powah!!!
DO you have a link where I can find these lugs & spacers? I need help, cause Im not too good with all this "offset" stuff & "spacing" Thanx For Any Help. Also can I put 1 inch spacers in the rear & not need longer lugs???
Old Nov 2, 2004 | 09:13 AM
Lordrandall's Avatar
www.crowautomotive.com sells spacers and adaptors for less than H&R. If you don't know much about offset and spacing, you really need to read up. If not, you are going to spend a lot of time and money 'test fitting' different size spacers.
Old Nov 2, 2004 | 09:26 AM
Jeff92se's Avatar
I'm needing a caw
Well for one, you don't need these rinky dink spacers to use them. And they are 16".
Originally Posted by rosamax
Are you joking?
Old Nov 2, 2004 | 09:27 AM
MaximaSE96's Avatar
Maxima Owner
Are you joking?
because if u know how to strip and polish they look better than z32 wheels
Old Nov 2, 2004 | 10:13 PM
VE Powah!!!
So do I need spacers or not? Im getting mixed answers??? I'm most likely to trust Jeff92SE, seeing as he is a "Moderator" & how many posts he has. Anymore help from you Jeff thanx! I need to know exactly what "Spacers or Lugs" I need or if I dont need them at all. Thanx
Old Nov 3, 2004 | 01:40 AM
bonzelite's Avatar
they actually look cool as heL$L. there was a thread about that topic not too long ago. they are 16" versions of the SE 3rd gen stockie 15s. i was surprised at how stout the car looked with those. i didn't know they were 16 until the issue came up. thought z31 and 3rd gen SE maxima wheels were the same. but nope. the 16s are dope.
Old Nov 3, 2004 | 07:33 AM
Jeff92se's Avatar
I'm needing a caw
http://forums.maxima.org/showpost.ph...86&postcount=1
Old Nov 3, 2004 | 03:11 PM
bonzelite's Avatar
thank you jeff for that.
now many questions arise: will the Z31 rims, or OEM 3rd gen SE rims, clear big brakes? like the Z32 brakes? or BlehmCo brakes? i just upgraded my front cals to skyline gts-t (z32). will i be able to run stockies ever again? and what about the mini-spare tire? will that clear big brakes? or do i need to get a Z32 spare? life is different now.
Old Nov 3, 2004 | 03:23 PM
Jeff92se's Avatar
I'm needing a caw
Well the skyline calipers are basicly Z32 4 piston calipers. But you never specied if you are running any bracket or larger rotor (IMHO necessary for any improvement in braking distance and not just fade resistance) So let's assume you are running these calipers on turned down Z rotors or something.
1) You will need a 16" rim min. Easiest to run would be the NA Z32 wheels. Those should clear dia / width wise. "should" being key here.
2) You can't use the stock 15" or the 16" Z31 wheels. Neither have the caliper clearance necessary. As you know the Z31s use a single or 2 piston caliper. Both on the inside of the caliper. The stock 15"s are too small also.
3) Donut. I put my spare on my bro's na Z32 on the rear and that's all I can say. His donut was a bit different. ie.. more room for caliper clearance.
Now the 2nd part is about the BBK kits. Min 17" rims. Need the proper offset and spoke design to clear either kit. Z32 spare would have no chance at clearing these two set ups.
Old Nov 3, 2004 | 09:20 PM
bonzelite's Avatar
jeff, i milled down the skyline rotor 3.5mm from the radius. i had to do this. so the rotor, now, is actually a hair smaller than OEM. the skyline and maxima rotor were the same diameter, the skyline rotor's width being thicker. way thicker. the brakes stop excellently even though they are still being broken in. the difference is mostly with fade over distance. there is practically zero brake fade. they put a death grip on the rotors.
i figured i'd be kissing goodbye the possibility of swapping back to OEM SE rims once i did this -point of no return. the cals are 4-pot. big. like lordrandall's, exactly the same setup.
i'm running skyline wheels, so the whole ensemble works sweetly. i used the skyline brake lines, too.
so i cannot use either z31 16" or maxima 3rd gen SE 15".
i guess i got to keep a skyline wheel in the trunk now. sh*t.
i gotta tell you, though, the 3rd gen SE should have had the z32 setup as standard equipment. that is really the actual brake for this car.
Old Nov 3, 2004 | 11:23 PM
Jeff92se's Avatar
I'm needing a caw
If you flat one of the fronts. You put the donut on the rear and move the good back to the front. You should really buy one of my rear bbk brackets and buy a set of turbo Z31 rotors. Gain an 1" in Diameter in the rears.
Old Nov 4, 2004 | 12:08 AM
bonzelite's Avatar
jeff, i am assuming the term 'donut' is jargon for 'spare.' i can get a z32 spare, then. that would take care of that. or---> if i keep the oem donut, i move it to the rear in the event i flat one of the fronts, so on and so on.
you have pics of the bbk's?
Old Nov 4, 2004 | 12:26 AM
Jeff92se's Avatar
I'm needing a caw
Rears? It's like the stock bracket but it moves the stock caliper out .5" to accomodate a 1" larger dia Z31 rotor. $75 shipped.http://community.webshots.com/album/156103082NbOYfr
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
0m3nc0w
Sep 11, 2015 05:21 PM
