INJECTOR Resistance
Old Nov 3, 2004 | 10:43 PM
aminus21's Avatar
INJECTOR Resistance
My #5 injector is gone, so I pull a used fuel rail from the yard.(from a 91 SE w/140k miles) I tested the resistance on the injectors on the rail. All of them read in the 12s, except for the #1 which read 18.xx, and #5 which read 40.xx. Both of those injector terminals are corroded and one of them is white, and the other is green. I think if I sand it down I can get the corrosion off, but do those readings mean that those two injectors are gone?????
Old Nov 4, 2004 | 04:15 AM
bhunter's Avatar
If they still read that way after you clean them up, then yes.
Old Nov 4, 2004 | 01:55 PM
aminus21's Avatar
what should I use to clean the corrosion off the connectors?
Old Nov 4, 2004 | 02:21 PM
DanNY's Avatar
Ad·min·is·tra·tor
contact cleaner...make sure you get some fine sand paper and sand/scrape off all the crap before you try to clean w/ the solution.
Old Nov 4, 2004 | 04:47 PM
aminus21's Avatar
Well some bad news... I cleaned the two injectors that were giving me a resistance of 18.xx and 40.xx ohms, and they havent changed. Lesson to be learned, "Take your muiltimeter with you to the junkyard IF you are buying used injectors"
Anyways.. Currently in the max (VG) I have 6 blue dot injectors. 5 of them have a reading of 11.xx, and the other one is completely dead.
So should I just replace the dead one, with one of the four 12.xx ones from the junkyrad which will leave me with (5) 11.xx blue dots in the car & (1) 12.xx black dots? Or should I throw in all four 12.xx ones from the yard, which will leave me with (2) 11.xx blue dots, and (4) black dots in the car?????????????
Is a lower reading better or a higher reading??
Old Nov 5, 2004 | 05:29 PM
bhunter's Avatar
They should all read between 11 and 12. A real low reading like one or two ohms is shorted. A high reading has high resistance.
Maxboy23
55
May 1, 2025 06:09 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
carid
Sep 17, 2015 05:00 AM
