Headlights don't work
Old Nov 9, 2004 | 10:26 AM
Dagger969's Avatar
Anyone know where all the relays and fuses are for the headlights? My low beams don't work but my high beams do. I have checked the two fuses under the hood on the driver side for each headlight and the bulbs are good. I just need to know if there is something im not checking. Thanks
Old Nov 9, 2004 | 10:43 AM
ChrisCheezer's Avatar
stock bulbs????
maybe the harness is melting?, pull-out and the harness to the bulb and see if its all melty inside..
Old Nov 9, 2004 | 10:48 AM
KLoWnPR109's Avatar
I had the same problem a lil while ago, and it was the bulbs
Old Nov 9, 2004 | 12:03 PM
Dagger969's Avatar
I bought two brand new bulbs, and the harnesses are fine. I checked them with a meter and they show no voltage on low, only on high fo they show voltage. I read some other posts about the switch, so im cleaning that up right now. Hopefully it'll help. Thanks for the posts
Old Nov 9, 2004 | 12:41 PM
Dagger969's Avatar
I posted this after reading about ten pages of threads and on about the 11th or 12th I found a post about the switch. A wire brush and some alcohol later, the headlights work. Thanks for the help guys.
Old Nov 9, 2004 | 01:51 PM
Greeny's Avatar
¯\(°_o)/¯
OH MY GOD!!!!!! SOMEBODY READ THE THREADS AND STICKYS!!!!...AAAAAHHHHHHHHHHHHHH!!!!!!!!
vingodine
45
May 21, 2016 12:46 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
KristyKarina
Aug 23, 2015 09:53 AM
kenc15
Aug 5, 2015 08:29 AM
