Is this mod possible?
Old Apr 16, 2001 | 07:22 PM
roman's Avatar
I was looking at the headlight assembly and noticed that the front glass lense could be taken off pretty easily because it is only held by two clasps on each side (as far as I know). Now what I am thinking is: could we put in a clear plastic or glass piece instead of our current thick headlight glass which has some kind of design(or whatever it's called) on it? I am sure that some company would be able to make one of those for our car. You know what I am talking about?
Any ideas?
Roman
Old Apr 16, 2001 | 07:51 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Any ideas?
Roman
if you put something thin instead of the stock assembly...it could be prone to melting....im not sure i follow what you are talking about
Old Apr 16, 2001 | 08:12 PM
Matt93SE's Avatar
STFU n00b!
You don't want to do that. The reason the glass has that design in it is to focus the beam correctly. if you remove it, your headlights wont' work worth a damn and make visibility near zero at night.
Projector lamps and others with the clear lens are designed differently, with the correct geometry in the reflector, which gives the correct beam pattern without the glass lens.
Old Apr 16, 2001 | 09:11 PM
Pervis Anathema's Avatar
Also,the headlight glass is high-strength poly-carbonate. You don't want to put some cheap *ss aftermarket glass in there. It will break when a bug hits it at 55 mph!
Old Apr 17, 2001 | 08:40 AM
roman's Avatar
Ok...it was just an idea.
Old Apr 17, 2001 | 02:23 PM
Brandon90gxe's Avatar
i had exactly the same idea, i konw what your saying. Itd basically be like the bmw lights without the two lights behind it. I dunno how you could do it, go to a high quality glass builder or something, but then youd have to stick something behind the lights to focus em so you can actually see with them.
lrb6805
Sep 30, 2015 08:12 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
