help runnin 4gauge wire from trunk to front
Old Nov 12, 2004 | 05:11 PM
blacks92seAuto
I need help finding a spot that is easy to get to, I dont want to remove my dash and crap to find the firewall wherever it is. I was thinking about making my own hole by drilling through somewhere, but it would be a decent size hole...need to run 4gauge and 3 other small wires through it. Ive heard of runnin it through the door, but my friend has it on his car and his door creaks over the slightest bumb because the wire rubs in the closed door....thanks for the help. also if you have any pics of how you ran your wires for an amp that would be nice...like where you ran the wire to the engine bay
Old Nov 12, 2004 | 05:55 PM
swowlinc's Avatar
1993 SE
All you gotta do is drill just above and to the left of your brake pedal into the firewall. A good idea is to pull back the drivers side carpet and tear off the stuff they got on the firewall before you drill. Look for any light coming through the firewall while youre under the steering wheel. Double check the location ,under the hood ,before you drill. That should do it.
Old Nov 12, 2004 | 06:23 PM
-shock211-'s Avatar
if you don't want to drill a hole you can run it through a rubber grommet that's located underneath the wiper motor. and i would suggest you run the wire from the front to the back. running from the trunk up is a real pita.
Old Nov 12, 2004 | 07:41 PM
blacks92seAuto
do I need a certain drill bit that is big enough(ofcourse) and strong enough to make it through the metal? also...i looked there and it looks like fuel rails or some kind of thin metal lines run near there..but my judgement could off....
Old Nov 12, 2004 | 08:42 PM
MrGone's Avatar
You do NOT have to drill
find your hood release cable gromet and run it through it I have a 4gauge wire running throught there in my car, and today just installed another 8 gauge wire onto a friends car (had a previous 8 gauge for his head unit and added a sub).
Snake it back under the kick panels and carpet, under the rear seat and into the trunk.
Old Nov 12, 2004 | 09:23 PM
blacks92seAuto
will i need to make any cuts or make the hole bigger some how, or is there already enough room to run the wire? I'll have to get on my back and look up at the hood release thing and follow it out. pic would be awesome...but thanks for the info. ill try looking tomorrow
Old Nov 12, 2004 | 09:47 PM
MrGone's Avatar
dont have pics on my servers or on this computer
pull the inner fender liner for the front drivers wheel, the back half towards the door. You will have to cut the gromet abit. The easiest way is to snake the cable through the engine bay (there is a few large holes by the battery) to the fender, through the fender to that gromet then push it though, once its through go inside and start pulling. It's easiest with the kick panel off.
because its 4 gauge you will want to snake it under the carpet, easiest way is just to pull the door sills out, and that center pillar part (its tricky at first but you'll get it ). then you can just pull up the carpet and stuff the wire down, get it far enough that it isnt buldging and that crap. Make sure you run the RCA's on the passenger side. Personally I run the remote wire with the power wire.
Old Nov 12, 2004 | 10:19 PM
probmxstyle's Avatar
I ran mine through the engine harness grommet in the driver side wheel well. You just have to pull out the fenderliner to get to it but doing this way you wont see any cable.
Old Nov 12, 2004 | 10:29 PM
MrGone's Avatar
are you sure it was the engines wiring harness. IIRC they fill it in with a urethane or something, pretty dang hard to poke through. I really wish i had my pics
blacks92seAuto
what is the fender liner? the black plastic?
Old Nov 12, 2004 | 10:35 PM
MrGone's Avatar
yeap (not the one that goes around the axle, the one that bolts to the inner lip of the fender)
Old Nov 13, 2004 | 12:58 AM
blacks92seAuto
oh its not the cv boot?
blacks92seAuto
thanks for the help guys
Old Nov 13, 2004 | 10:36 AM
L3LIX's Avatar
heres the pic of where you need to put your wire through in order to get to the rubber grommet inside the fender
P.S sorry about the dirty engine bay its some kind of rust proofing that the last owner put on
P.P.S i got the full writeup on my cardomain site
Old Nov 13, 2004 | 11:04 AM
Mizeree_X's Avatar
Getting back to his roots
Originally Posted by L3LIX
You won't be winning any awards for "Cleanest Engine Bay" anytime soon.
Old Nov 13, 2004 | 12:28 PM
MrGone's Avatar
[IMG]http://memimage.cardomain.net/member_images/11/web/671000-671999/671029_12_full.jpg[IMG]
d00d you dont need to snake it all the way back there. There are 2 really big holes right next to the battery that go into the fender, just snake it through there, then you dont have this extra cable snaking through your engine bay and it looks really clean and hidden.
Old Nov 13, 2004 | 03:22 PM
L3LIX's Avatar
haha thanks for pointing that out man
Old Nov 14, 2004 | 12:34 PM
Yeah it am sure it was it. It was one thick **** but i know the wire will never wear through and ground itself out. It looks very clean also.
Old Nov 14, 2004 | 02:18 PM
Matt93SE's Avatar
STFU n00b!
better late than never...
http://mattblehm.com/pics/car/interior/stereo/wiring/
look at pics 32-34
the rest are here:
http://mattblehm.com/pics/car/interior/alarm/
Old Nov 14, 2004 | 02:20 PM
Matt93SE's Avatar
STFU n00b!
[.IMG]http://memimage.cardomain.net/member_images/11/web/671000-671999/671029_12_full.jpg[/IMG]
Oh.. FYI.. that's not rustproofer. that's just DIRT. that color of car is notorious for doing that. Get a bottle of simple green or Gunk engine cleaner and a plastic bristle brush and go to town.
Old Nov 14, 2004 | 05:26 PM
unsprung's Avatar
Or dirtiest
If you don't feel like removing the fender liner, just go for the straight-forward hole drilled through the firewall. The process took me ~30 mins TOPS, starting with a smaller bit and working up to one large enough to adequately support my 4ga power cable, along with filing down the jaggedness from the hole. I tried for 3 hrs to figure out how I could do it without drilling, but just succumbed to that at the end.
Make sure you have the kick panel & plastic pieces from the driver's side to the backseat removed before you begin. You can then run the wire from the top of the carpet on the driver's side into the area under the door sill & all the way to the back (4ga fits fine and doesn't show, but you might want to pay attention to make sure it doesn't block the fuel tank lever). Removing just the bottom part of the rear seats is all that's necessary (simple pull up on that piece and it comes free easily) as you can then push the wire into the trunk. While you're at it, run the blue remote wire over to the stereo location as well in the same route as the power cable from the trunk.
Old Nov 14, 2004 | 07:29 PM
L3LIX's Avatar
it feels really wierd to touch, it feels like some kind of tar or somthing,
i thought its dirt as well at first so i tried washing it off, but it just repeled water and didnt do anything, so i kinda gave up on that
and yeah a bottle of simple green will help alot
thanks alot for the advice btw
Old Nov 14, 2004 | 08:45 PM
MrGone's Avatar
steam cleaners are gods gift to the lazy man
Old Nov 14, 2004 | 09:17 PM
Matt93SE's Avatar
STFU n00b!
that's ten years of dirt and oil built up on the paint. a good degreaser and a plastic brush will make quick (relatively) work of it. spend a couple hours scrubbing in there and it'll look a LOT better.
I've seen several people with engine bays worse than that, and they look cleaner than the outside of the car when they're done. amazing.
Matt93SE
May 24, 2019 02:58 PM
vingodine
45
May 21, 2016 12:46 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
JoshG
21
Sep 4, 2015 09:04 PM
TMartinLVNV
Aug 16, 2015 01:48 PM
