Need help!!!
Need help!!!
Cant figure this out...i noticed a couple days ago that if i'm stoped at a red light or at idle...the heat goes kinda cool, but when i step on the gas it heats right up...so i replaced the thermostat (thx mygreenmax94 for the pics) and did a flush...when i was in the repair shop it seemed to clear it up...and when i drove around after for like 10 mins it was good, but then it started to happen again...anyone have any ideas??? thanks
try letting the air out of the system. There is a screw on the motor (drawing a blank where now since I dont have any GXEs to look at but think its around the intake manifold) that you can loosen up to allow all the air to get out of the system. You just open it up and keep it open a little bit after your water/AF mixture comes out and then close it back up.
Originally Posted by nismo3366
we did a flush ( this was all done in a shop with me and a machanic)...there would still be air in the system??? thanks
my heater problems were due to my heater valve located in the middle of the firewall at the top. it has some vacuum hoses going into it. my symptoms were different than yours though. i just moved the vacuum hoses around.
so no ones had this probelm before...i'm frash out of ideas
Have you made sure the heater core lines going into the firewall are hot when the engine is warmed up?
just for the heck of it try the air release. It doesnt cost a thing and takes only a second. I have heard others say that air in the system will cause crazy things like this. If its not air in the system then there is a problem with the core or maybe even the water pump who knows. Try to release the air and see what happens since that is so easy then move on from there. And yes there could be some in there after (especially) a flush.
maybe the heater core. Maybe someone that has had this problem will be able to help out.
