popping noise when i turn or hit bumps
Old Nov 15, 2004 | 08:15 PM
<Racer M>'s Avatar
i can hit a small bump and i still hear this popping noise, and it doesnt always happen when i turn, happens alot but not all the time when i turn the wheel to the limit. i know i need a front end alignment, and a mechanic told me i might need a strut, he didnt really examine it, because i came there for something else at the time.
Old Nov 15, 2004 | 11:17 PM
rikshaman's Avatar
it maybe the cv joints
Old Nov 16, 2004 | 05:43 AM
<Racer M>'s Avatar
i just changed one on the side that is popping, didnt effect the noise one bit.
Old Nov 16, 2004 | 05:52 AM
alpicone's Avatar
Check the ball joints.
Old Nov 16, 2004 | 11:49 AM
wawa92gxe's Avatar
check your sway bar end link quickly, you might need new bushings, linkages.
put on some polyurethene stuff, you won't regret.
denga
Old Nov 16, 2004 | 10:04 PM
Jackrabbit's Avatar
Definatly check sway bar end links. I just had to fix my passenger side. same noises before hand.
Old Nov 16, 2004 | 10:17 PM
DanNY's Avatar
Ad·min·is·tra·tor
ball joints
tie rods
wheel bearing
strut bearing
rack bushing
rack itself
Old Nov 17, 2004 | 10:17 PM
bvtran's Avatar
94c Big Max
check your control arm bushings. if its badly worn out, the joint will run out of shock absorptions. Eventually, making plenty of noises over bumby roads. Check your sway bar t-link, where your front sway bar is connecting to the control arm. The links probably snapped. Just get yourself a new pair of link cuz the stock one isn't very reliable.
boomerbrian
Oct 31, 2018 10:25 AM
captchaos
Mar 15, 2016 12:18 PM
LtLeary
Sep 14, 2015 12:33 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
