vg- jim wolf upgraded!
Old Nov 16, 2004 | 05:27 AM
erniesduckie's Avatar
i was wondering which z fuel injectors i could use with computer and if anyone had any places you can get them cheap! i also have a problem with slight intermitent ping/knock mostly at idle every now and them, already changed the o2 sensor?
Old Nov 16, 2004 | 06:10 AM
MethMax's Avatar
so what is the jim wolfe part about? did you get the JWT computer? what do you have done that you need 300z injectors.
Old Nov 16, 2004 | 06:22 AM
DanNY's Avatar
Ad·min·is·tra·tor
unless you're running massive nitrous or FI you don't really need bigger injectors than the stock one. if your engine is not running right stock then upgrading it would make it worse.
Old Nov 16, 2004 | 06:34 AM
-shock211-'s Avatar
are the vg injectors 180cc?
i can't remember...
Old Nov 16, 2004 | 11:28 AM
lophix's Avatar
intermittent ping/knock after ecu upgrade...what grade of gas are you using?
Old Nov 16, 2004 | 11:34 AM
mtcookson's Avatar
i can't remember...
1234567890
Old Nov 16, 2004 | 11:42 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
run premium gasoline and make sure if you ever advanced your timing you knock that back down to stock levels. upgrading your injectors is pointless as dan mentioned unless you're doing some serious upgrades in which case the ECU would need to be reprogrammed again
Old Nov 16, 2004 | 01:44 PM
i have been using prem gas, i have pop charger, all new exhuast from warp, urp pulley, and no my timing is not advanced. why would you need to reprogram the computer if you used different fuel injectors when i have the jim wolf one? i thought you could do that?
Old Nov 16, 2004 | 02:44 PM
mtcookson's Avatar
they are set to open the 180 cc injectors for a certain amount of time. if you use bigger injectors they'll still be opened the same amount of time but since they are larger would injector more fuel. basically, if you run larger injectors on an ecu programmed for smaller ones, it will run quite rich.
Old Nov 16, 2004 | 09:20 PM
Maxininct's Avatar
Well said mtcook. I kinda felt like i was reading one of those "books for dummies" when i just read that lol.
Old Nov 16, 2004 | 09:22 PM
Maxininct's Avatar
oh yea and btw cookson, the engine is in, tuning next 2 days, should be running this weekend!!!!!
Old Nov 17, 2004 | 07:34 AM
mtcookson's Avatar
awesome! let me know how it goes
Fbana41
Aug 29, 2016 12:18 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Dasmith
Sep 23, 2015 08:28 PM
