Brighter back up lights?
Old Nov 17, 2004 | 12:50 PM
bhunter's Avatar
Anyone done anything to get more light when backing up? It seems like there is no light back there at all, but they're on.
Old Nov 17, 2004 | 01:45 PM
Scope's Avatar
Im izz sexay
If you ever pulled the tails off you'll see some type of clear plastic piece on the reverse side. Find a way to pop that out then do the same for the turn signals. Now every light at the bottom is clear and should be brighter. But first replace the bulbs.
Old Nov 17, 2004 | 02:30 PM
DMad8724's Avatar
you could replace your reverse light bulbs with some hyper whites or something, or as he said clear your tail, or do both and
Old Nov 17, 2004 | 06:13 PM
wolfpack_5150's Avatar
Apple Pie Monster
anyone tried installing leds?
http://superbrightleds.com/led_prods.htm
I was thinkin bout it cuz our reverse lights do suck.....think the 90Degree bent ones would work or no?
http://superbrightleds.com/1157.htm
scroll down 6 times
Old Nov 17, 2004 | 07:34 PM
DMad8724's Avatar
I looked into everything LED while I've been wiring my e36 projectors, and I've decided to go with LED turn signals and that's about it, I may go with LED tails someday..but as far as reverse lights:
"LED bulbs are generally not as bright as standard incandescent bulbs, they have many advantages over filament bulbs (longer life, faster on/off times, lower power consumption, more vivid colors) but brightness is not one of them"
Taken right from the LED bulb page..
Old Nov 18, 2004 | 01:07 AM
nubiannupe's Avatar
OG Maxima.org Member
I don't know, David... I'm STILL working on my little project (been slowed up because of money/moving issues), and they look bright enuff to ME. Even in some preliminary tests where I mounted them to the car to look at them from a distance (and no, these are NOT mounted - but just to show how bright they are)
So, maybe there are mitigating factors that come into play when they say that brightness isn't one of the advantages of LED bulbs. Or, maybe in the LED 'bulbs', they use a lower mcd-rated LED - as opposed to the 10k mcd I'm working with...
Old Nov 18, 2004 | 04:53 AM
DMad8724's Avatar
Unfortunately, I can't see the pictures, maybe later in the day they'll appear..maybe your custom LED tail lights will be brighter, especially with 10k ones, but it sounded like that guy just wanted to buy a drop-in LED bulb and be done with it, that's why I advised against it...I'm nearing completion on my front end, just waiting on my LEDs (might come today) and then I'm going to mount them and test them in the turn signal, I'll PM you and get your opinion.
Old Nov 18, 2004 | 05:48 AM
Brad92SE's Avatar
Wow, those look really good!!
One question, how are you dealing with the curve in the tails? Are you putting leds in that part also, or just in the flat area?
Old Nov 18, 2004 | 06:54 AM
DMad8724's Avatar
Hmm, I'm at school now and those look really good! I think I'm going to replace the brake light bulbs with hypers whites so they're really bright, and also put reverse lights (might use LEDs now, after seeing yours, PM me and give me some information on where you got them PLEASE!) in the stock reverse light section and in the turn signal section (will have to clear my tails) as I'm changing one of my brake lights (will still be a brake light when the signals off) into a turn signal, as well as the 194 bulb in the curve of the tails
King_Ten_Ahead
Sep 30, 2015 04:27 PM
doobadoo
Aug 15, 2015 06:43 PM
Samedi
Aug 13, 2015 04:05 PM
kirkhilles
Aug 8, 2015 10:53 AM
MikesChevelle
Aug 6, 2015 11:36 AM
