Back Seat
Old Nov 24, 2004 | 09:21 AM
93MaxMurf's Avatar
Back Seat
Could someone possible explain to me or give me a site that explains how to take the rear seat out of my maxima. i need to get my back speakers out and i'm am pretty sure this it the only way to do it. Thanks
Murf
Old Nov 24, 2004 | 09:34 AM
Aaron92SE's Avatar
NWP Engineering.com
http://www.geocities.com/craigbrace/
In the How To section.
Old Nov 24, 2004 | 09:35 AM
93MaxMurf's Avatar
Thanks my speakers are blown to hell. Really need to get them out.
Old Nov 24, 2004 | 10:54 AM
avmaldo's Avatar
errr. you cant get to them from the trunk?
Old Nov 24, 2004 | 11:10 AM
Loe max's Avatar
thats only if you want to do it the quick way
Old Nov 24, 2004 | 11:20 AM
93MaxMurf's Avatar
no, with mine, they are dropped and screwed in from the trunk, i have tried many times to get them our from there but it wont work, it is a gxe with the **** 6 1/2" speakers not the bose 6x9's and the only way to get them out is to take off the carpeting and the covers over them and to do that i need to take out my back seat.
Old Nov 24, 2004 | 11:38 AM
avmaldo's Avatar
that sucks
Old Nov 25, 2004 | 07:55 PM
Maximaniac's Avatar
Hi 93max , I got recently changed my speakers an know how to do ....
if you lift from the side(from open door) the bech not the back seat .. looking at the back towards the trunk you will see a skrew . unskrew this one "dont remove". then go to the other door side and do the same . then lift the back seat and unclip it from the top .then unskew and remove the brake light ... then from the trunk the'll might be some white plastic pins to remove upwards where the speaskers ares.might be green or blue.the you can slide the panet on wich the speakers panel in on and than change speakers ... to put back is reversal of removing... hope this helps......
then
Old Nov 25, 2004 | 08:29 PM
AscendantMax's Avatar
^^ it's screw, not sKrew
anyhow, craig's website pretty much shows ya how to remove the back seat. i personally find it easier just to remove the seat bottom before removing the back rest portion.
Old Nov 25, 2004 | 08:54 PM
Epacy's Avatar
Unsuccesful STL Coordinator
It is the most silly design. You have to take off the backseat to change the speakers. Nissan at it's best. The seat is easy to remove with a sturdy screw driver at the corners.
JRod28
Dec 29, 2023 09:56 PM
JoeWhit
Sep 20, 2015 08:01 PM
doctorpullit
Aug 20, 2015 05:15 PM
King_Ten_Ahead
Aug 13, 2015 09:46 AM
