need quick advice on cracking tranny open
Old Nov 26, 2004 | 05:03 PM
acidspit86's Avatar
hey i got my transmission off my car now and took all the bolts off but im having a hard time getting it open. any tips?
manual, btw
Old Nov 26, 2004 | 06:35 PM
goon9's Avatar
...Open it? why?
Old Nov 26, 2004 | 07:42 PM
acidspit86's Avatar
to replace the bearings. i got it open but now i cant figure how the hell i remove the gears. i got all the snap rings off that i can find
Old Nov 27, 2004 | 11:03 AM
-shock211-'s Avatar
i assume you have a two or three prong gear puller handy...you'll need it to pull off the gears.
when i was helping a buddy of mine rebuild his tranny we had to more or less make some tools to get the job done. you may find things that way too. good luck.
Old Nov 27, 2004 | 01:50 PM
acidspit86's Avatar
oh i was talking about the gearsets as a whole, not pulling individual gears
Old Nov 27, 2004 | 02:47 PM
Matt93SE's Avatar
STFU n00b!
Ummm, do you have a service manual that goes step by step through the tranny disassembly process?
If not, then DO NOT crack this thing open. you have to do everything in exactly the right order, or you f*** everything up and you might as well throw it in the trash if you just rip it apart like that.
Edit.. well you've already got it torn open, so you're in it for the long haul..
still follow the service manual step by step in order to get the shafts out and pull the bearings off. you don't have to touch the gears at all. just pull the bearings off the ends and press the new ones on.
http://mattblehm.com/pics/car/tranny/IM001413.JPG
you can see the bearing separator tool in the left side of this pic.
you're going to need one of those guys, and they're not cheap (unless you buy a crappy one from harbor freight). around $60-90 each for one big enough to pull a 3 1/2" bearing..
Also follow the pre-load procedure exactly and have the right shims on hand, or you're goign to get to do this alll again very soon. yuck.
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
