Install Driver lights?
Has anyone installed driving lights/fogs on there car that didnt have it before? My max didnt have fogs when i got her. And i just bought some from another orger. Can i run the remote that came with it threw the firewall without making a hole. Or should i just hook it up to stock wiring that when i turn on lights the come on as well? The reason i ask is i have the angel eye lights that was in the gd. And you press 1 angels come on press again and the lights press again and both off.. I want both on at once. Anyone that has an idea let me know thanks.
hook them up so the same power source and please run a relay to prevent fuse burnouts. You can hook the angels up to the corner sidemarker (little bulb) and the main up to the head lights. If you do this without a relay upgrade your stock wiring because they will burnout.
I did mine without a relay but I had to put a higher wattage fuse in because the stock one kept blowing out. I put myself at risk for wire shortage and other stuff. But it's been a year now and I'm finally getting everything done correctly.
hey i suggest that you dont run your fog lights with the headlights parking lights. One you can fail nys inspection. Two chances of shorting any wire and or fuse. Three most fog lamps arent created to stay on all the time you will be going thru bulbs like a mother if the fog lamps are high wattage. I suggest try to get the factory fog lamp switch w/ harness and run it with that. again just my 2 pennies
. Also if i get the harness Off of like a parts car or something. Will it be plug and play with my car or will i have to mod some **** in?
Originally Posted by aziphrale
what do you mean by done correctly? And way2 be i have florida plates. No inspection for me
. Also if i get the harness Off of like a parts car or something. Will it be plug and play with my car or will i have to mod some **** in?Thread
Team STILLEN
Aug 10, 2015 04:29 PM
kirkhilles
Aug 8, 2015 10:53 AM
