Need a couple socket sizes
socket size to remove bottom guide pin on front brake calipers?
socket sizes to remove starter-to-engine bolts?
I'm at work, need info, can't access the car currently. Can someone help me? N/M Just need it for starter-to-engine bolts.
I gotta get one, mine was stolen
Fortunately, the ones that I left in my car weren't but that still leaves me with 8,10,12,14,15,17mm
I thought I'd rotate the tires while I was changing the front pads also, now the car's steering wheel is steer'd to the left instead of the right
Originally Posted by DARHAW-MAX
Get one of these:
[IMG]http://content.sears.com/data/product_images/009/33596/00933596000-dlv.jpg[IMG]
For most of the stuff on the car, a 10, 12, 14, 17, 19, 21, 27, 36mm socket(having both deep and standard can prevent some headaches) will be all you need. + Philips and Flathead (a few different sizes helps too). A set of pliers and some wrenches are nice too. (I started out small but kind of kept going
Now's a good time to get
Sears Craftsman 60 pc. Mechanics Tool Set $24.88 (or $19.20 YMMV)
http://fatwallet.com/forums/messagev...ord1=mechanics
$5 off coupon
http://f.chtah.com/i/27/217789800/prem_coupon1.jpg
$5 off coupon
$5 off coupon
$5 off coupon
if matt wants to update his FAQ page for changing pads, the socket size is 14mm for the lower guide pin. there is alot of grease+dirt on the passenger side brake line where it meets up with the caliper
knight_yyz
Nov 1, 2015 01:34 PM
it only takes $10 on my smallblock
