Blehmco ground kit?
Old Dec 2, 2004 | 07:16 AM
yelowd's Avatar
Blehmco ground kit?
Has anyone used that ground kit to get the auto tranny to downshift quicker? Just curious if it works.
Old Dec 2, 2004 | 08:04 AM
blacks92seAuto
its not specifically to make your tranny downshift more...what it does, is beefin up the ground points for alot of the sensors, hopefully giving quicker readings to the computer which would in return make the car shift down faster. If your grounds are all making good contact, and your tranny is shifting slower than normal, then maybe its the beginning of a tranny problem?
someone correct me if im wrong, but i think thats how the ground kit qorks on quicker shifts?
Old Dec 2, 2004 | 08:58 AM
yelowd's Avatar
From BlehmCo-
"These kits include 8 awg ground straps to the factory sensor grounding points, alternator, and an additional 4awg ground strap to the battery.
Benefits are a much smoother idle and acceleration. for Autos, the 2-1 kickdown at stoplights is much more noticeable. I'm sure you've noticed that when you slow to 1-2mph and try to take off, the car is extremely sluggish and wants to stay in 2nd-- or even 3rd gear. With the ground kit installed, that is almost nonexistant. it downshifts properly and pulls away from the light. no more mashing the gas and watching your tires go up in smoke when it finally kicks down into 1st at 15mph!"
I should have been more specific. My tranny shifts fine, I just get annoyed by the delayed or non existant kick down in the situation he is referring to.
Old Dec 2, 2004 | 09:03 AM
DanNY's Avatar
Ad·min·is·tra·tor
don't buy the wires thinking that it'll solve any transmission problems.
assuming all the components are working CORRECTLY and your shift lag is due to a poor ground or a weak ground...then yes the wires will help. but if you're having a problem with the tranny mechanically then ground wires won't help you much there.
Old Dec 2, 2004 | 10:24 AM
yelowd's Avatar
Cool. I don't have a tranny problem, it just does have that annoying down shift lag after you've slowed down. If no one else has this happen, than I have a problem. Honestly, I wouldn't buy the kit either. Get A CAI before I spend $60 on some wires. I thought I might pull up the schematic and throw in the grounds.
Old Dec 2, 2004 | 11:00 AM
blacks92seAuto
here is the cheap option...the route I took...and they worked fine for me, no fitment problems.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33574
Old Dec 2, 2004 | 02:24 PM
aziphrale's Avatar
What car Do you have? The vg Motor Or ve?
Apr 16, 2020 05:15 AM
Pied
Sep 26, 2015 03:29 PM
