Wisdome of the org needed
Wisdom of the org needed
Once again I call on your wisdom. Can someone let me know what I need to fix this?
http://img.photobucket.com/albums/v2.../DSCN5013c.jpg
http://img.photobucket.com/albums/v2...s/DSCN5012.jpg
at first I thought my old clutch line was leaking but after replacing it with the stainless one I still am not able to get the clutch to function properly. When I was bleeding it I noticed a leak where I circled and bought a hose clamp and clamped it. Now it bulged up and not sure whats up. Haven't drove my car for a week now and would like to get it up and going asap.
If you need more info or pics please let me know.
Mike
Mike
Thanks, at least I know what the thing is now. I believe I can go from here.
Hopefully replacing this will do the trick
Thanks again.
About the clutch line. Does the hole on the screw need to be lined up with the clutch line or can you just screw it on without worrying about that.
Hope this makes sense
Thanks again.About the clutch line. Does the hole on the screw need to be lined up with the clutch line or can you just screw it on without worrying about that.
you don't have to worry about it at all. the way the banjo connector is designed is that there is a "valley" so that the fluid can go through the connector with the bolt in any position. this ensures that its tightened correctly without any worry of lining anything up.
Originally Posted by Jeff92se
and decide to
us(like THAT will happen)
Originally Posted by nubiannupe
No, Jeffy... we wanna ask YOU, and ask, and ask... until you get
and decide to
us
and decide to
usNo, Jeffy... we wanna ask YOU, and ask, and ask... until you get
and decide to
us
TonyJr
Aug 20, 2015 12:14 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
