help, prep work VE 5SPD!
Old Dec 5, 2004 | 09:34 PM
blacks92seAuto
Would like to know from you pro's out there what I can start doing now, while my car is still an auto...to make less work for me later. I was thinking that I could go pick up a clutch pedal assembly and clutch master cylinder.....would I be able to install that and have no interferance other than the clutch pedal being there...and what else could I do and still have my car driveable.. and anyone got info on how they installed the clutch pedal assembly and master cylinder and maybe tips how to mount the pedal? Thanks
Old Dec 5, 2004 | 09:37 PM
HTPerformance's Avatar
-Shock211- did the swap on his VG he might have some insight
KlownPower did it too on his VG
part #'s might be different on a few things, but installation will be the same.
Brian
Old Dec 5, 2004 | 09:50 PM
Cliff Clavin's Avatar
Way out West
This just occurred to me...you probably need to get the brake pedal, too. I think the AT brake pedal is wider than that of a manual tranny car. You need to double check with guys that have done the swap.
Old Dec 5, 2004 | 10:17 PM
blacks92seAuto
your probably right....because I was looking at that earlier today and was like, "hmmm where is this clutch pedal gonna mount, not much room next to this brake pedal, gonna have to shave an inch off each side...hmm.."
seriously, that was my thought ealrier, even though Id just get a smaller brake pedal.
And can I be reasured that if I decide to do the swap and not swap for the VI manifold, that my car wont blow up and for most part should be normal...and also, if I do that, can I still use my stock auto ecu?..I know I have to rewire like 4 wires to get a few things working properly.
Old Dec 5, 2004 | 10:30 PM
Jeff92se's Avatar
I'm needing a caw
5-sp swaps have been discussed alot. Post in one of those threads
MAXSE5SPD
Sep 17, 2022 04:00 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
ef9
Aug 27, 2015 10:17 AM
kenc15
Aug 5, 2015 08:29 AM
