veering when shifting
Old Dec 7, 2004 | 09:54 AM
darnellzook2's Avatar
93 max SE auto tranny. Steering feels loose and dodgy under heavy acceleration, and just after transmission shifts into third car veers quickly and noticeably to the right. I do know that I need an alignment due to bad tire wear and I have waited to do it until I replace both front axles, which I have just completed. Veering problem existed before I replaced the axles. Suggestions? Could this be motor mounts or is there another part of the suspension or steering system I should be looking at? Thanks
Old Dec 7, 2004 | 09:56 AM
internetautomar's Avatar
mod or sell?
control arm bushings.
I sell complete control arms as well as the bushings.
Old Dec 9, 2004 | 09:19 AM
buuuuuuuuuuump
Old Dec 9, 2004 | 09:49 AM
Minty91GXE's Avatar
"My customer is complaining about “bump steer”. Will an alignment fix it?
This condition is the result of a change in front wheel steering angle created by the upward and downward ("bump") movement of a vehicle's front suspension. Both toe-in and toe-out can change during bump steer. It is also a common result of a tie rod (end) not following the same arc path of the wheel to which it is connected. Alignment will not correct this. The most common cause is bent parts on a street use vehicle."
Old Dec 9, 2004 | 10:10 AM
Wiking's Avatar
If I remember right, one Nissan Service bulletin speaks of engine rev to steering servo -problem.
If you suspect this kinda problem, one place could be combing the TSB's
Nissan Maxima Technical Service Bulletins:
Look for example http://maxima.theowensfamily.com/tsb
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
