Center Console Gauge Cluster
Old Jan 1, 2005 | 08:22 PM
  #41
HTPerformance's Avatar
Patience is a virtue daniel-san...
-Mr. Miagi (Karate Kid)
Old Jan 1, 2005 | 09:52 PM
  #42
blacks92seAuto
link didn't work for me
Old Jan 1, 2005 | 09:54 PM
  #43
Sorry, had to move it. Try this one. http://forums.maxima.org/showthread.php?p=3528966.
I will edit the original.
Old Jan 2, 2005 | 06:46 AM
  #44
Only 7 spots left! Get one while they last!
Old Jan 2, 2005 | 11:13 AM
  #45
MrGone's Avatar
Old Jan 2, 2005 | 11:14 AM
  #46
ghostridden's Avatar
i got one!
Old Jan 2, 2005 | 12:51 PM
  #47
Here are the direct light pics that y'all wated.
Brian
Old Jan 2, 2005 | 07:56 PM
  #48
Only 6 spots left! Get one while they last!
Old Jan 2, 2005 | 08:30 PM
  #49
kcidmil's Avatar
Love it, I like this a lot better than the pillar. I'm going for the whole sleeper thing, and this will help out a lot. Now I just have to convince the wife.
Old Jan 3, 2005 | 02:46 PM
  #50
Get to convincing before they are gone! 6 spots left
Brian
Old Jan 3, 2005 | 02:52 PM
  #51
blacks92seAuto
Brian
how long would it take for you to make and ship(1week usually) and how can we pay you?
Old Jan 3, 2005 | 05:12 PM
  #52
Maxima-4DSC's Avatar
YoU CaNt SeE mE
i got one, i got one !
Old Jan 3, 2005 | 06:00 PM
  #53
MrGone's Avatar
I was wondering if you would
I wonder if Jeffy will jump on this
Old Jan 3, 2005 | 06:27 PM
  #54
As soon as everyone (12) get their money in, I will begin production on this set. I plan to get everything done by the end of January and ready to ship out by early February. Again this is all dependant on all twelve slots being filled up within the next week. Otherwise the final production date will be pushed back until I get 12 orders.
You have a PM regarding payment.
Brian
Old Jan 4, 2005 | 11:10 AM
  #55
-shock211-'s Avatar
looks good.
Old Jan 4, 2005 | 08:43 PM
  #56
Thanks shock, are you up for one? only 6 spots left...
Brian
Old Jan 4, 2005 | 09:33 PM
  #57
Jeff92se's Avatar
I'm needing a caw
So you have solved the climate control thing?
Old Jan 5, 2005 | 06:34 AM
  #58
-shock211-'s Avatar
Brian
nope,
i've already got a custom gauge install done.
Old Jan 5, 2005 | 03:51 PM
  #59
I will be making the brackets, they will be reversible, so you can choose whether you want to mount the Climate in the 1st of 2nd DIN. If you mount it on the lower DIN you will have to remove som plastic on the rear dash piece, this won't be visible and is up to you. Mounting it in the upper DIN won't require any modification of the rear dash piece.
Brian
Still 6 spots left, fill them up, so I can begin production.
Old Jan 5, 2005 | 03:55 PM
  #60
Jeff92se's Avatar
I'm needing a caw
Sounds good. PM me the payment info. If I pay in full, can you start in on mine 1st?
Old Jan 5, 2005 | 04:32 PM
  #61
Hectic's Avatar
all this talk about double din flip down screens...i hate to be conceded but just wait till i unveil my mod..been in the works since '98 but i totalled that max, now i have my replacement so it's just a matter of buying the parts and diggin in. give me a couple months or maybe during the summer..probably won't wait that long though.
Old Jan 5, 2005 | 04:40 PM
  #62
PM sent.
Not sure how to address the start on yours first... they will be made at the same time. But the ones who are payed in full now will ship as soon as they are ready, and do not have to wait for everyone else to get their final payment in.
Brian
Old Jan 5, 2005 | 04:42 PM
  #63
Jeff92se's Avatar
I'm needing a caw
I was kidding a little. Anyway, you get the bbk wheel info you needed? Or do you need me to measure still?
Old Jan 5, 2005 | 09:12 PM
  #64
still looking for the measure... if you have a chance, still looking for the radius from the axle center to the outside of the caliper on the front.
Thanks Jeff,
Brian
Old Jan 6, 2005 | 12:31 AM
  #65
blacks92seAuto
could anyone tell me where the location of the water temp sensor is on the VE..I looked all over in the chiltons, but no cigar....in the process of running some gauges...and this is the last one I need to hook up. Thanks
Old Jan 6, 2005 | 12:56 AM
  #66
MrGone's Avatar
Lower intake manifold, drivers side. Look for a little red connector IIRC. Not 100% sure which one is which right now :-/
Old Jan 6, 2005 | 04:10 AM
  #67
I can only tell if you buy a cluster....
Brian
Old Jan 6, 2005 | 02:15 PM
  #68
5 Clusters still available sign up ASAP.
Brian
Old Jan 7, 2005 | 05:13 PM
  #69
4 cluster left.... http://forums.maxima.org/showthread.php?t=366687
get them now!
Old Jan 7, 2005 | 05:29 PM
  #70
blacks92seAuto
turned out i didn't need it...i had to get a t fitting, 2 barbed, ends, and I performed a throttle body coolant bypass just a few hours ago, in the freezing cold.
Old Jan 7, 2005 | 05:31 PM
  #71
blacks92seAuto
Brian
Ill make my own center consule gauge cluster then!
Old Jan 7, 2005 | 09:03 PM
  #72
anywho.... 4 more left.... get em while they are HOTT!
Brian
Old Jan 7, 2005 | 11:16 PM
  #73
3 more.....
Old Jan 7, 2005 | 11:27 PM
  #74
2 spots left....
Old Jan 8, 2005 | 02:56 AM
  #75
Hectic's Avatar
is that just an insert that goes in the cc slot? or is it for the entire trim piece.
Old Jan 8, 2005 | 03:54 AM
  #76
blacks92seAuto
its a $55 insert......and you get relocating brackets for the cc
Old Jan 8, 2005 | 09:50 AM
  #77
mtcookson's Avatar
i forgot to ask, what size guages fit in there?
also, my money is sent.
Old Jan 8, 2005 | 11:13 AM
  #78
2-1/16" gauges are the size.
Thanks Mark.
Old Jan 8, 2005 | 11:42 AM
  #79
MrGone's Avatar
2-1/16
10chars
Old Jan 8, 2005 | 01:39 PM
  #80
Only 2 left! Get on it...
