Sensitive Steering
Sensitive Steering
Hello people,
I have this extra-ordinary feeling that my Maxima has become too smooth for this time of the year (Iowa weather). I am worried if this is a precursor to something major with my steering or something.
I will link my previous two posts 1. about a Grinding noise when I turn in parking lots http://forums.maxima.org/showthread.php?t=352745
2. a minor rear-ending incident http://forums.maxima.org/showthread.php?t=357124 .
Do you guys/gals see some pattern here? What self inspection I can do so that I can wait till my upcoming 90K inspection? Thanks in advance.
-MM
-MM
This is a 13 yr. old car you have. Chances are the suspension parts{tie rods,ball joints,control arm bushings,etc} do need to be atleast inspected, if not replaced.
I know half of my suspension needs to be replaced....Not enough$$$$$$
ECU Diagnostics
Hello Everyone,
I wanted to diagnose the cause of rough idling and reduced power for my 91 Maxima. Now, my question is how to reach to the ECU? Can anyone explain it step-by-step?
Very much appreciate your help.
-MM
(Btw, I cannot create new threads and hence this modification of old thread)
-MM
Sensitive steering / Grinding noise
Thanks for all your opinions guys!
-MM
Originally Posted by mukundan
Does anyone know who can post new threads in these forums? At present I am not able to post new threads. What are the criteria to be eligible for new posts?
It'd be easier to pm a moderator and ask.
Read this:
http://forums.maxima.org/announcement.php?f=11
My question is somewhat of the same kind. I have replaced almost all my suspension parts except springs and shocks (113k on the car). I have never felt this before (kind of obvious though) but since I changed wheels to a lot wider (225/50/16) I'm having a hard time crusing around. I'll have to almost fight the car for the steering wheel coz it keeps wanting to follow any trace in the road... if you understand me.
This is of course bound to happen with that much larger wheels, but my question is; Can you make the steering any harder so it won't be as sensitive to traces in the road?
That sounds like bad control arm bushings to me.
actually it sounds normal.
when you increase tire width it tends to follow the ruts more.
So there is no way of hardening steering a little bit so it won't be as sensitive to ruts?
...a little bit so it won't be as sensitive to ruts?
http://forums.maxima.org/showthread.php?t=418687
Bushings can be bought under name of Bluebird, med kronor.
Originally Posted by Wiking
Oh whu did u destroy that fiat uno? It had 145 wide tires - no problems... Take belt off, fill with smtg else than A/T fluid. tHeres a DIYThule solution that helps a little; 5kronor:
That sway bar... I thought it was suppose to be bolted onto the 'spring bolts' or what it is called..? Does it work to just bolt them to the chassis like you did?
...Does it work to just bolt them to the chassis like you did?
http://www.cardomain.com/ride/842139/5
Dunno about the facts. Feelin is that chassis is now more rigid, u could lift my car from that DIYThule. Check out hows kcdmil's bar:
Btw, there are no bushings available for the Bluebird here either
It's not that important at the moment anyway. I took it apart and pushed and pulled the control arms today and could find no gap or anything loose. It's probably as Brian says... just wider tires are more sensitive to ruts.
I'll try your idea Wiking. Change to a thicker oil, maybe that'll help a bit... hope the pump can take it though.
...hope the pump can take it though.
Hey make sure u know what stuff u will use. I dont know, only A/T fluid is rec.
- Could u find smaller diameter pump wheel?
- Bleed bypass, maybe valve closes it when idle?
- First take belt off to tst to feel how u like it...
Why max wants to go wherever: Broad tires, grooved road. Toe in adj NG.
worldwiderecognized
Sep 30, 2015 01:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
