Need help installing a double din kenwood radio, 4X6, and 6X9
Here's my problem. My bose system is slowing dying and I want some new stuff installed. I want to do it myself and need help badly. Everyone wants to charge from 100-175 to just do installs. I have a single din kenwood already installed with a 10 disc changer. I just need instructions on how to put in the double din radio and how to change the door and rear speakers. Tell me what parts do I need in order to get started. If possible I need step by step instructions with pictures would be nice.
Hugss and Kisses and happy hoildays all my maxima owners out there :) |
Check this out in the stickies. instructions It's under the FAQ. It will give you instructions for lots of stuff including stereo things. It's pretty easy after that. :happyface
thank you nell
I appreciate it |
Originally Posted by nek
thank you nell
I appreciate it |
hey I have one question
Do I need to buy anything in order to install the double din radio |
you will need an antenna adapter because of Nissan's dual-diversity antenna system
get it from any audio store or ebay also need a wiring harness so you can wire your new radio and plug it into the stock harness both those things are ~$10-15 each |
get it from any audio store or ebay also need a wiring harness so you can wire your new radio and plug it into the stock harness both those things are ~$10-15 each I have a single din kenwood already installed with a 10 disc changer. |
Originally Posted by nelledge
nek already has an aftermarket HU. Most likely, that stuff is all set.
So Nelledge is right, you should be ready to go. The bracket that are on the side of your current unit should screw right into your new double din and it'll fit right in the opening. |
do ya'll think the dxp 4020 is worth the 125 I'm paying? since it is a year old now
I like the radio for the fact I like being able to listen to some of my old tapes. My old kenwood is tape deck with a 10 disc changer on it.
you mean you haven't transfered all your tapes to CD yet? Do it fast man, those tapes can only last so long.
© 2024 MH Sub I, LLC dba Internet Brands
