Help with injector
Old Dec 30, 2004 | 11:01 AM
jrhdrydr's Avatar
Help with injector
I have finally reached the stage in disassembly where i can finally pull the injectors out. Unfortunately, they appear to be stuck. The first and last time i had an injector replaced i remember the mechanic pulled it out using pliers. Of course the completely destroyed the head of the injector. Well, i have also destroyed the head and the injector is still stuck. I have removed the injector rails, but i didn't purge the fuel lines prior to disassembly. Does anyone have any suggestions?? Help.
Ps can i drill it out. i figure if i drill the edges it will break the seal and therefore come out. what do you think???
Old Dec 30, 2004 | 11:25 AM
internetautomar's Avatar
mod or sell?
pull the rail and tap it out from the bottom gently.
it'll come out just takes time and finesse
Old Dec 30, 2004 | 01:13 PM
Wiking's Avatar
Yes, do like internetautomator suggests. With drill you endanger your alu cyl head.
- Use rust solvent. let soak one day...
- use heat on the cyl head [expand], freezer gas [contracts] on the injector.
- is it possible to use screw tap?
- Try to get it turning, solvent will go in, hit tangentially with screwdriver/small hammer.
Maxboy23
55
May 1, 2025 06:09 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
msellas
Sep 23, 2015 09:16 PM
