flywheel
Old Dec 31, 2004 | 10:08 PM
chewy3194's Avatar
flywheel
This may be a stupid question but does an automatic maxima have a flywheel.I was looking at the unorthadox flywheel but I am not sure if this is only for manual tranmissions.
Old Dec 31, 2004 | 10:55 PM
Wiking's Avatar
There's no such thing as stupid question. Stupid answers are abundant, I'm an expert giving those...
Here's one:
I have not opened my auto, but I suspect I have empirical evidence: as flywheel edge has gears where starter motor fits its revolving gear as I start my engine, I suspect smtg similar has to be there as is manual tranny cars. (My car started at least last year
Old Jan 1, 2005 | 01:08 AM
Jeff92se's Avatar
I'm needing a caw
Auto = Flexplate
Manual = flywheel.
Look in the autozone manual in the stickies
Old Jan 1, 2005 | 10:59 AM
twinkle's Avatar
yea what he said, and basically a flexplate is a flywheel with no friction surface, it is just something for the tourque converter to bolt to
Old Jan 1, 2005 | 11:09 AM
Jeff92se's Avatar
I'm needing a caw
Actually it's just there to hold the ring gear for the starter
Old Jan 1, 2005 | 11:29 AM
twinkle's Avatar
and the torque converter bolts to it...doesnt it, i just took an auto apart like last month, if not then what is that part called..?
Old Jan 1, 2005 | 11:50 AM
chewy3194's Avatar
In other words i cannot install an unorthadox flywheel because an automatic does not have the same type of flywheel.
Old Jan 1, 2005 | 04:08 PM
internetautomar's Avatar
mod or sell?
in other words, you don't need one because there is no real weight savings to be gained
Old Jan 1, 2005 | 05:19 PM
MrGone's Avatar
First off the flywheel will be heavier than a flex plate.
Second the flywheel is about 7 times thicker than a flex plate and does not have the mounting holes for the torque converter
Old Jan 1, 2005 | 05:30 PM
blacks92seAuto
if you want tranny upgrade, do a valve body upgrade or a 5speed swap and then put a lighten flywheel in..
Old Jan 1, 2005 | 07:42 PM
GRNMAXDMON's Avatar
5-speed swap
Old Jan 7, 2005 | 05:58 AM
MISTER BIG's Avatar
with a lightened flywheel, what are the improvememnts... i can understand that my RPM's would lower and raise quicker due to the mass decrease when rotating the flywheel..
how would this improve performance ..? anybody drive a max with a lightened flywheel.?
Old Jan 7, 2005 | 06:53 AM
Matt93SE's Avatar
STFU n00b!
it simply allows the engine to accelerate faster. for daily street driving, I really don't see much difference, but on the track it's pretty obvious how much better it is.
I wouldn't necessarily recommend it for drag racing though, since you want a heavy flywheel to help you launch the car. once you're rolling, the light flywheel will help- but you can make up more time by getting off the line better than you can by saving 10lb of rotating weight on the drivetrain.
Old Jan 7, 2005 | 06:58 AM
MISTER BIG's Avatar
hey matt,
i ask because i am replacing the clutch and was thinking about lightening while i get it surfaced...
do they use a similar machine as they do with crank balancing to ligthen the flywheel properly.? i want to get it done, but DO NOT want to end up with a un-balanced wheel..
what kind of shop do you suggest i get the lightening done at i.e. machine shop, engine rebuild shop ?
thanks
Old Jan 7, 2005 | 08:01 AM
Matt93SE's Avatar
STFU n00b!
any shop that can balance a crank or flywheel will be able to do it. I took it to a local race machine shop that builds engines for John Force (lucky me, they're 3 min from my old house and are pretty cheap for basic work.
but just make sure they can balance it afterward.
you can take about 3lb out of it by cutting off the back ring and smoothing out the sand cast portion along the back.. won't hurt the strength and will make a difference. those suckers are still heaaavy though.
stock: 20.2lb
lightened stock: 17.9lb
fidanza: 10lb.
Old Jan 7, 2005 | 08:18 AM
MISTER BIG's Avatar
i cant wait to see the difference.. along with my shortened shifter and re-inforced mounts....wone feel like im driving a 3 speed truck.. :O)
matt, can you explain to me the process of how the lighten the flywheel, do they go back and forth between the machining and balancing, one machine does all ?? i just want to make sure they can do it, because alot of places say they can do it.... i wanna ask them questions to test them..
thanks a bunch..
Old Jan 7, 2005 | 08:36 AM
Matt93SE's Avatar
STFU n00b!
if they can machine a crank or balance an engine, then they can do this. basically all they do is take material out of the back of the flywheel, then rebalance it when they're done.
print out the pic of the back of Jeff's flywheel and show them... you can see where material has been taken off it when you flip yours over and compare it.
plan about 3 days for the work though- usually it takes a while. this isn't like simply resurfacing the friction surface.
KabirUTA13
19
Oct 17, 2015 02:15 AM
kenc15
Sep 25, 2015 06:38 AM
