Relay switch question..HEY CRAIG!!!!
Old Oct 5, 2000 | 10:17 AM
Greyboy
I just put fog lamps on my 93 GXE. I need to know the parts # for the relay switch for the (fog lamps/ cornering lamps). Please tell me what it is b/c the Nissan dealer near me doesn't know jack and I don't want to blow $25 on the wrong one. Thanks!
Hey Craig I printed out all the instructions on your web site and I'm going to try those mods of yours. Thanks a lot for all that info! It's really helpful!
Kevin C.
Old Oct 5, 2000 | 11:36 AM
Rit's Avatar
Rit
You can buy a heavy-duty automotive
relay from Radio Shack for $6, and it will fir perfectly, and do the same this, and then e-mail me the $19 that you saved.
Old Oct 5, 2000 | 04:01 PM
«§»Craig B«§»'s Avatar
Kevin C.
what kind of foglights did you get? did you get the nissan kit from the dealer? if not, how did you wire them? I think that the gxes have almost everything prewired for fog lights like the SE, except for the relay and switch. if you used the stock wiring, and just need to add a relay, the nissan relay is a 4 prong one that is just like the ASCD (cruise control) relay (which is the blue relay in the set of relays in front of the battery; 1st relay on bottom left, empty spot behind it is fog light relay) if you want to test the fogs, take out the ascd relay (with a small flathead screwdriver on the side and pull) and put it in fog spot; cruise won't work until you put the relay back ,but fogs should work if everything else is right
let me know if you have anymore questions
Old Oct 6, 2000 | 12:56 PM
Greyboy
I can't remember which brand they are, but they're nice! They're black, low profile, oval, have a highly polished glass lense on them that are blue, and give off an amber light.
I'm putting them on my 93 GXE that didn't come equiped with them and I didn't buy a kit. I bought the factory SE switch instead of the GXE switch (I'm told there's a dif in style). I did use the factory wiring, but I had to cut off the plugs for the factory fogs and soder on the new ones. It worked for me last time, but that car (93 SE) already had fogs on it. I hope this works b/c if it doesn't, I'm going to be hopping pissed! Thanks for the info!
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
lrb6805
Sep 24, 2015 05:03 PM
