Anyone with a WSP B pipe and aftermarket sway bar?
Old Jan 8, 2005 | 11:14 PM
dmontzsta's Avatar
Ford Only.
Just wondering if there is a good bit of clearance there?
My B pipe is starting to hit the stock sway bar, this is NOT a WSP it is a local exhaust shops work that was done to the car around 7 years ago. I now have a 2k muffler I want to put on, but want to get a new b pipe, trying to get all hooked up for smog test this month. I want to get a b pipe that will EASILY clear an aftermarket sway, since I will be getting one eventually. I am also sick of hearing the metal on metal sound...
Thanks! any pics would be great.
Old Jan 9, 2005 | 12:29 AM
505max94se's Avatar
Any b pipe should clear the stock sway bar if the pipe is held up far enough. I have the wsp full 2 1/2" system and a st rsb and it clears it easily. If the wsp b pipe and muffler aren't held up high enough it won't clear on the stock rsb. The st rsb also has some what of a u shaped bend in it to clear the exhaust.
Old Jan 9, 2005 | 04:17 PM
KLoWnPR109's Avatar
How are your exhaust hangers? I have the WSP b pipe and it clears the stock sway bar easily. Doesn't really help you much though, har har
Old Jan 9, 2005 | 06:01 PM
Mizeree_X's Avatar
Getting back to his roots
Addco RSB doesn't have the U-bend, and it'll hit my WSP 2.5" b-pipe sometimes when I am going over bumps. My stock hangers are a little worn, but I don't really care at this point. A ghetto trick I saw was to buy some screw clamps to "tighten" the exhaust hangers up, gives you a little more clearance. Beats buying new hangers.
Old Jan 9, 2005 | 06:06 PM
dmontzsta's Avatar
Ford Only.
All hangers from front to back are brand new. I thought that would help, it didnt really help, dont know what the deal is, they have been fine for 7 years then all of the sudden, the only thing I can think of is motor mounts, but dont think they would effect it back there.
Old Jan 10, 2005 | 01:32 PM
blacks92seAuto
if for some reason your car is **** eyed, take your WSP B pipe to your exhaust shop and have them install it for $50, they will make it clear your rsb
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
