heat takes seemingly too long to get warm
Old Jan 10, 2005 | 05:43 PM
aw89maxSE's Avatar
I have had both the heater core and thermostat changed out and so the heat is pretty good, but it seems like it takes awhile to get going. Like you know how the more your foot is on the pedal, the faster all the circulation is going, the hotter it gets.....well to me it seems as I have to drive for awhile to get the heat going and I'm not sure why. Even with having a remote start on, it doesn't warm up that fast.
Old Jan 10, 2005 | 06:27 PM
internetautomar's Avatar
mod or sell?
has it been bled properly?
you do have a 39" car
Old Jan 10, 2005 | 07:55 PM
aw89maxSE's Avatar
I have never bled it(the coolant I'm guessing) and I think the only times it has been was when the shop replaced stuff. Should I try bleeding it? How and will it make a difference to bleed it and what do you mean 39" can?
Old Jan 10, 2005 | 09:48 PM
sara92max's Avatar
There is a coolant purge valve on the intake. Check out a Chilton or Haynes manual and it will tell you how to do it. Also, check the coolant level, if low, it could cause the problem you discribe....
Old Jan 10, 2005 | 10:19 PM
Jeff92se's Avatar
I'm needing a caw
Does the engine take alot longer to warm up? You won't get warm air until you warm the engine. Unless you use the ac/defrost set on warm.
Old Jan 10, 2005 | 11:05 PM
aw89maxSE's Avatar
Nope, engine warms up just fine
Old Jan 11, 2005 | 07:08 AM
mod or sell?
39" car.
that's how high you are supposed to raise the front end with the car running and the rad cap off, in order to properly bleed the system
Old Jan 11, 2005 | 09:14 AM
SUAVEB's Avatar
I took my 94 to the dealership and I had the same problem, however they said that it is very rare for the heater core to go bad. I had them service my lines. All they did was bleed the coolant lines and my heat works allot better. It doesn't take as long as it use to, however I have an electric start and I let my car warm up with the heat off for at least 10 minutes before I leave and that does the trick. It only coast me $65.00 at the dealership. Hope this helps.
Old Jan 11, 2005 | 12:07 PM
aw89maxSE's Avatar
Doesn't TOO rare around here. I know mine went out and it was a b**** to put in
Old Jan 11, 2005 | 12:09 PM
Jeff92se's Avatar
I'm needing a caw
Could be the valve that controls when/how the water flows into the heator core. Could be stuck/malfunctioning.
Old Jan 11, 2005 | 12:27 PM
LMaRiE91MaXiMa's Avatar
I had a similar issue with my 91, except it didnt neccesarily take along time to warm up and have the heat work. What happened with mine is:
I would drive the car for awhile (at least 10-20minutes) so the engine was definitely warm, and the heat would be working during that time too - but then for some odd reason, the heater would start pumping out cool air (the thermostat was set all the way in the red which is obviously the hottest it can go)..but the air would just turn cold for no apparent reason - then become warmer again a few minutes later (or after shutting it off for awhile and turning the fan back on).
The solution: I had a tune-up done about 2 or 3 weeks ago in which I also had the mechanic flush and fill the radiator - My heat has been working great and is back to its normal, HOT self all the time!!! Must have just been low coolant...
kjlouis
Nov 24, 2018 06:09 AM
Samedi
24
Apr 19, 2016 12:49 PM
dr3am
25
Oct 22, 2015 08:53 PM
02nissmax
Sep 5, 2015 01:50 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
