300zx specs
1990 300ZX Non-Turbo Specifications (2 seater)
Dimensions
Length
169.5"
Width
70.5"
Height
49.2"
Wheelbase
98.5"
Track
58.9" front / 60.4" rear
Curb Weight
5 speed 3219lbs
Automatic 3247lbs
Engine
Type
VG30DE, 3.0L 24valve DOHC V6
Displacement
180 cu. inches / 2960cc
Horsepower @ rpm
222hp @ 6400
Torque @ rpm
198lb-ft @ 4800
Induction
Multiport fuel injection with dual intake
Compression Ratio
10.5 : 1
Drivetrain
Drive Configuration
Front engine, rear drive
5 speed gear ratios
1st 3.214
2nd 1.925
3rd 1.302
4th 1.000
5th 0.752
Reverse 3.369
Final Drive Ratio 4.083
Automatic gear ratios
1st 2.785
2nd 1.545
3rd 1.000
4th 0.694
5th ----
Reverse 2.272
Body / Suspension / Chassis
Body Type
All-steel monocoque body
Drag coefficient
0.31
Weight Distribution
55% Front / 45% Rear
Suspension
Front Independent multi-link, coil springs, hyrdraulic shock absorbers and stabilizer bar
Rear Independent multi-link, coil springs, hydraulic schock absorbers and stabilizer bar
Steering
Speed-sensitive power power rack & pinion
Turning Circle
34.1'
Wheels
16 x 7.5-in. cast alloy
Tires
225/50 - 16
Brakes
Anti-Lock Braking System
Front 4-piston 11" vented disks with power assist
Rear 2-piston 11.7" vented disks with power assist
Fuel Capacity
18.7 gallons
Dimensions
Length
169.5"
Width
70.5"
Height
49.2"
Wheelbase
98.5"
Track
Curb Weight
5 speed 3219lbs
Automatic 3247lbs
Engine
Type
Displacement
Horsepower @ rpm
222hp @ 6400
Torque @ rpm
198lb-ft @ 4800
Induction
Compression Ratio
10.5 : 1
Drivetrain
Drive Configuration
5 speed gear ratios
1st 3.214
2nd 1.925
3rd 1.302
4th 1.000
5th 0.752
Reverse 3.369
1st 2.785
2nd 1.545
3rd 1.000
4th 0.694
5th ----
Reverse 2.272
Body Type
Drag coefficient
0.31
Weight Distribution
Suspension
Steering
Turning Circle
34.1'
Wheels
Tires
225/50 - 16
Brakes
Fuel Capacity
18.7 gallons
Originally posted by Pervis Anathema
How the hell can the VG30E in the 300zx make 222 hp?!? What needs to be done to my Max to get the same results. (besides an engine swap)
Originally posted by Soon2BMaxed
wow the 1/4 time is in the 15s? darn i thought it was quicker than that. oh well my parents will be happy with that. how much trouble would adding a supercharger or turbo be and is it possible?
I've seen pics of a supercharged NA but they had to pull the A/C, so it has been done. But it's not very common and as SkyMax says, you're better off just buying a TT.
There are a handful of people that have done TT->NA swaps in their 2+2s and convertibles. But they either have a lot of money, or did it themselves. Actually, you will need a lot of money if you do it yourself or not!
Other than that, NOS is probably the most cost effective way to make the NA fast.
I suggest checking out www.twinturbo.net if you have anymore questions.
Well, put a few numbers together.. 222+ NOS = 272 to 297hp.
a stock 300ZX TT is 300hp... so if your'e dumping around 280hp into one, you're going to be almost as fast at a stock TT.
of course you can still add NOS, computer, and all kinds of turbo goodies to a TT and have 400+ HP for about the same money you'd have a N/A modded enough to keep up with a stock TT.
If your looking for speed don't get an NA.. a TT will always leave an NA in the dust. A NOS'd NA is quick but still not quick enough to beat a TT. My friend has dynoed over 430hp in his Z TT and he has only done basic mods. His name is SilverZTT on Twinturbo.net.
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
