Rack and Pinnon
Old Jan 16, 2005 | 11:58 AM
killermax3's Avatar
Rack and Pinnon
can someone help me and either give me a link to where the rack and pinnon is or give me a real good description on where it is. because i am leaking a lil bit of transmission fliud so when i took it to the shop they said it was rack adn pinnon and it will be $778!! so i want to see if my dad and i can do it ourselves. thanks for your help.
Old Jan 16, 2005 | 12:06 PM
Loe max's Avatar
I think this is what you're looking for http://www.autozone.com/servlet/UiBr...3d801f5837.jsp
If you have to ask where the steering rack is at, I sure hope your dad knows, otherwise I think you're going to be in trouble fixing this yourselves
Old Jan 16, 2005 | 01:03 PM
killermax3's Avatar
well thank you for the site i hope its the same for my year because it says 93-98 and mine is a 91. also yes i know where the terring column is, i just needed to know if anyone had a picture of the steps. thanks again.
Old Jan 16, 2005 | 02:55 PM
avmaldo's Avatar
by a repair manual. oops i meant buy
Old Jan 16, 2005 | 04:52 PM
Matt93SE's Avatar
STFU n00b!
buy a repair manual, but you don't really need it. I've typed out the instructions for this several times in the last few weeks. plan a full dya to do it, but it's not really difficult.
6 bolts, two tie rod ends, two flare nut fittings. slide it out of the fender well, replace.
and you don't have to remove the steering wheel. Just make sure you don't turn the wheel once you get the steering shaft unbolted from the rack. if you do, you'll ruin the spiral cable, and they're $250 or so from the dealer.
Old Jan 16, 2005 | 05:51 PM
MAXI's Avatar
check the other posts. i just saw this discussion last week.
edit:
here's the thread.
http://forums.maxima.org/showthread.php?t=368259
Old Jan 17, 2005 | 08:02 AM
GRNMAXDMON's Avatar
$778 thats alot of money.
Old Jan 17, 2005 | 10:57 AM
killermax3's Avatar
thanks for all your guys help ill most likley do the job this weekend and ill let you all know how things turned out. thanks again for the write up thats exactly what i needed
mikeg75
Nov 30, 2015 05:12 PM
fastcarny
Oct 12, 2015 07:06 AM
06maxima55
Sep 28, 2015 04:29 PM
Serotta33
Sep 17, 2015 12:14 PM
