pics of broken cross member
Old Jan 23, 2005 | 05:58 PM
95turbo gxe's Avatar
Well After one night at a little heavy throttle this happend. I est that im only pushing about 250lb of torque. Well when I crank up the boost ill have to reenforce this one.
Old Jan 23, 2005 | 06:19 PM
«§»Craig B«§»'s Avatar
What kind of turbo setup are you running to get 70 ft/lbs? That's a big gain.
Matt93se broke his crossmember (maybe twice?) before too. I think he's welded it up now and beefed it up a little.
Old Jan 23, 2005 | 06:21 PM
well im running ct26 but maybe my numbers are off.
Old Jan 23, 2005 | 06:29 PM
3rdmaxse0's Avatar
hell Im on my 3rd crossmember. got em cheap enogh $10 piece I think im gonna stock up on em when my friend starts building his VGT.
Old Jan 23, 2005 | 06:31 PM
mtcookson's Avatar
stock Z's have somewhere around 230 ft. lb. of torque if memory serves me correctly. only being 20 ft. lb. more would be easily attainable having 9:1 compression, a better turbo, better intake manifold, and higher flowing exhaust. i personally wouldn't be surprised if it were a bit higher.
at 15% drivetrain loss (probably a bit low) i'm pushing 250 ft. lb. at the flywheel and i know his car is faster than mine at the moment. in the end the only way to find out would be dyno....
Old Jan 23, 2005 | 06:47 PM
awesome
as far as I knew, he had a VG (~180 ftlbs) that he put a turbo on
his cardomain pics show that too
pretty clean looking setup (cleaner setup than other turbo guys in this thread - but if you're pushing 250 ftlbs then I'm definitely jealous no matter how it looks).
Old Jan 23, 2005 | 07:06 PM
mtcookson's Avatar
hey now... my setup is clean... in a redneck sort of way.
on the stock Z thing i was comparing a smaller turbo, factory intake and exhaust, crappy intake manifold, and 8.3:1 compression to what his setup would be.
Old Jan 23, 2005 | 07:14 PM
avmaldo's Avatar
That cross member makes me want to
Old Jan 23, 2005 | 07:30 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
been thru 2 myself, hey matt theres a new project for you....beefed up crossmembers
Old Jan 23, 2005 | 07:36 PM
Hey hey now Marks set up is nice. Mark can do so pertty amazing things.
Old Jan 23, 2005 | 07:40 PM
Michael's Avatar
Back in a 3rd Gen.
check his page...its probably on there. He has a beefed up one since he has broken 2 or 3
Old Jan 23, 2005 | 11:38 PM
505max94se's Avatar
I beefed up mine when I did my clutch because I didn't want to have to deal with it later.
Old Feb 22, 2006 | 03:21 AM
crazy4maxima's Avatar
OK mines went on me. Any idea if the cross member is the same for ve and vg? Where can i get a second one? I was driving and hit a pot hole and next thing my shifter is loose. I got it to the mechanic and got it on the lift, the member was about to brake completely on the front engine mount because it rotted away Help.
Old Feb 22, 2006 | 08:30 AM
Mizeree_X's Avatar
Getting back to his roots
Junkyard? www.car-part.com? Dealer? Org classifieds? C'mon man, its just like any other Maxima part. Can the mechanic temporarily reinforce it while you search for a replacement?
Old Feb 22, 2006 | 06:11 PM
pimpp85's Avatar
ok help me out wat is a cross member... thanks
Old Feb 22, 2006 | 06:30 PM
4dscPat's Avatar
It's the beam that goes from near the bumper to the back of the engine bay, under the engine. It supports the engine.
Old Feb 22, 2006 | 06:44 PM
vansskaterfreek's Avatar
the crossmember on my 228k maxima was cracked, alsmost all the way through..... so you high mileage guys might wanan check that thing
Old Feb 22, 2006 | 06:47 PM
pimpp85's Avatar
thats what i figured thanks for the clarification
Old Feb 23, 2006 | 11:05 AM
update, my mechanic found a junk crossbeam and replaced it, and saw that my rear motor mount is gone. called local star nissan and he had a new one sent. this is adding up.
Old Feb 23, 2006 | 11:07 AM
Alex_V
why buy an engine mount when you can fill it with polyurathane or similar? next time I have my engine out I am.
~Alex
Old Feb 23, 2006 | 11:29 AM
PunkFriday's Avatar
Power Dorifto Extraordinaire!
does anybody make stronger motor mounts and crossmembers for the 3rd gen? if matt (blehmco) found out a way to make them, that would be a worthwhile investment for my tax refund... along with his grounding kit... and a few other things.
Old Feb 23, 2006 | 12:13 PM
Matt93SE's Avatar
STFU n00b!
fill your stock mounts with poly (or contact LordRandall about doing them for you), and I'll reinforce the crossmembers for $100 each, shipping included.
tarun900
19
Dec 20, 2021 06:57 PM
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
