why didn't anyone tell me! ve and vg rear brakes arent the same.
Old Jan 30, 2005 | 04:16 PM
ChrisCheezer's Avatar
well today I did my suspension swap (9 hours straight)..... and rear brake swap. (doh!)
-took all my suspension out of the vg, and put it in the ve... didn't expect any problems at all...until I got to the rears, OMG, I had both rear right assemblies off and trying to fit the caliper on the struts from my VG. after an hour of trying to convince myself there should be no problems.. I finally unbolted the caliper on both cars and swapped calipers... driving my self nuts.
-to make a long story short the other sides took me 45 min. and I have no e-brake on either car. (yet) the e-brake cables are different too... WHY
-i asked the max.org if I would have any problems with this swap and like 100 ppl said "nope should be fine"...or "everything is the same"
- I wana slap the a$$whole at Nissan that make the rear brake change from those years.
-at the end, everything looks good and torque to spec...just waiting for the sway bar links to snap off...
- my brain hurts I need some sleep.
pic's up when i get around to it...
Old Jan 30, 2005 | 04:28 PM
Loe max's Avatar
Good to see everything worked out
Old Jan 30, 2005 | 04:42 PM
internetautomar's Avatar
mod or sell?
part #'s never lie
and you didn't ask me
Old Jan 30, 2005 | 04:51 PM
- OH yeaH! i forgot to add i stripped out a single front strut mount bolt (ones of the three on top) dont ask me how i did it.. but the bolt first went all the way in and then when i was tourqing it just spun.. its on tight, but it wont tighten or lossen... im just going to leave it untill i see it move... that and hopeing the rear brakes will be fine on the VE is all that im thinking about now... its killin me
Old Jan 30, 2005 | 05:06 PM
HTPerformance's Avatar
so you put GXE drums on a VE???
Old Jan 30, 2005 | 05:20 PM
drums?!?! heck no... thats my point though
- it seems like all the rear 3rd gen calipers are the same.. but their not, i found out the hard way
-1992maxman: did you break your wrist?
Old Jan 30, 2005 | 05:24 PM
sprained it snowboarding last weekend....
Old Jan 30, 2005 | 06:01 PM
Mizeree_X's Avatar
Getting back to his roots
Its not a VG/VE thing. After a certain date (10/90 if I am not mistaken), Nissan switched to a different rear brake setup. That info is all over the org and there are different part numbers for everything. Oh well.
Old Jan 30, 2005 | 08:52 PM
MrGone's Avatar
why didn't you just remove the strut from the housing and put it on the VE, and vice versa?
The wheel bearings are different aswell, along with the rear caliper brackets, etc. Thats what the Jeffy/Matt rear BBK kit is based off of....
Old Jan 30, 2005 | 09:53 PM
-why why why why why.... i dunno
- how the hell do you warm a 5 spd up in the cold, with no e brake.... i can't start the car and go back inside, cuz my car will roll down the hill....lol (thats goin to suck).. i need to find some wheel chucks... aka bricks
-the vg brake cable will fit this car right? or am i screwed an going to hafta "make" the cables fit.
Old Jan 31, 2005 | 06:44 AM
Matt93SE's Avatar
STFU n00b!
no, just swap the brake cables over. it'll take you a couple of hours. very easy.
see my other thread on the forum titled "rear brake question" for all the info you need on that.
and I could have told you from experience that the early/late model brakes won't fit each other.
Nissan did it because the later models were easier to work on and safer on the parking brake cables than the early models. It was an improvement over time thing, not a "we're going to change this just to **** you off" thing.
Old Jan 31, 2005 | 07:12 AM
ok cool,thanx matt, just swap at the "T" junction under the heat shilds. i'll get on that sometime this week,
Old Jan 31, 2005 | 12:09 PM
are all maxima rotors, 89-99, the same?
Old Jan 31, 2005 | 01:04 PM
lalo's Avatar
ask internetautomart he should be able to give you the part numbers for the disk, if they are the same part #, then Yes, if different part #, then No.
Old Jan 31, 2005 | 02:25 PM
thanx Copernicus
Old Jan 31, 2005 | 03:58 PM
mod or sell?
year brake down as follows:
89-99 front Rotors same all
89-90 Rear Rotors
91-1/94 Rear Rotors
2/94-03 Rear Rotors:
Any questions?
Old Jan 31, 2005 | 04:44 PM
Matt93SE's Avatar
STFU n00b!
your 2/94 is a bit off.. unless they started making 4th gens in February... wouldn't surprise me, but the '94 stuff is the same as the '93.
Old Jan 31, 2005 | 04:50 PM
maximaboi's Avatar
so did you go from drum to disc? is that correct?
Old Jan 31, 2005 | 04:56 PM
he did disc to disc... just different disc age...
Old Jan 31, 2005 | 05:49 PM
mod or sell?
production date info was provided by brembo, autospec, aimco, bendix.
so although the changeover date is a bit early, maybe that was the model year change.
hmm... 2 new posts coming up!
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
egali045
Aug 16, 2015 01:19 PM
RealityCheck
Aug 5, 2015 06:18 AM
