Rear brake question
Old Jan 30, 2005 | 07:01 PM
mtnbikeair's Avatar
Rear brake question
I was wondering how hard/ if even possible logistically it would be able to put discs on the rear of my car. I have drums now and i am getting new wheels which will expose my brakes alot and i want discs on back now too. Is it possible? If so what all is involved parts wise and labor wise? Thanks as always
Old Jan 30, 2005 | 07:10 PM
HTPerformance's Avatar
yes it is possible. you need to find an SE and take the rear hub/spindles and brake stuff from that.
Brian
Old Jan 30, 2005 | 08:19 PM
Mizeree_X's Avatar
Getting back to his roots
If you have drums in the rear then you have a GXE, not an SE. There is a writeup for the rear disc conversion on 4dsc.com
Old Jan 30, 2005 | 08:53 PM
aminus21's Avatar
Does anyone know until exactly what month/year SE that the rear hubs can be taken from??
Old Jan 31, 2005 | 05:38 AM
mtnbikeair's Avatar
Does the GXE still have the VG30E in it then?
Old Jan 31, 2005 | 06:39 AM
Matt93SE's Avatar
STFU n00b!
ALL GXE models have the VG30E.
the only 3rd gen that doesn't is the 92-94 SE model, which has the VE30DE.
You can get the rear disc setup from ANY year 3rd gen, even from a GXE with ABS.. just remove the ABS sensor from it and it bolts right on.
You'll need the entire rear strut assembly. basically just unbolt the strut from the car as if you were changing the springs, and pull the brakes off with it. then bolt it onto your car.
You'll also have to replace the parking brake cables, which are a PITA but it must be done.
Expect to pay about $300 for parts and it will take 6-8 hours of work the first time you do it. I did it in about 4 hrs flat a couple weeks ago.
here's my writeup on it:
http://mattblehm.com/faq/rear_disc_conversion.html
And the pics.
http://mattblehm.com/faq/rear_disc_conversion/
the DCPxxxx series were when Kaleb and I did the first conversion on my old GXE.
the disk 1,2,3 directories at the bottom are when we did the conversion on Kaleb's GXE.
Man, that way back in the day! I think winter of 99-00 is when we did the conversion on Kaleb's car, and mine was the summer of '99.
Old Jan 31, 2005 | 08:05 AM
internetautomar's Avatar
mod or sell?
if you are going to do it, get all the info you can off the donor car as there are some production changes along the way.
Old Jan 31, 2005 | 08:19 AM
lalo's Avatar
like matt93se Said, Just get the hole spring/shock rear suspension intact w/ disks/calipers already installed. This way you dont forget small part that will delay the install. I think you will also need to change the E-brake cables.
check this out
http://www.mattblehm.com/faq/rear_disc_conversion.html
edit: Should have read the hole thread some one alrady gave this link.
Old Jan 31, 2005 | 06:17 PM
mtnbikeair's Avatar
I guess my next question, is would i be better off spending 300 dollars somewhere else on my car for now? I dont have any mods other than a high flow air filter and wheels. Should i go for brakes or something else?
Old Jan 31, 2005 | 06:21 PM
mod or sell?
brakes and suspension first IMHO
Old Jan 31, 2005 | 06:49 PM
aminus21's Avatar
what he^^ siad. Brakes and suspension is kinda of like a maintenance thing. Youll feel a big difference with the discs. I wish I knew about the drum to disc conversion 2 years ago. We had a 91 SE that we sold, I could have swapped my drums onto that for the discs..oh well,,its junkyard time
rbuswell
Nov 17, 2016 04:54 AM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
egali045
Aug 16, 2015 01:19 PM
RealityCheck
Aug 5, 2015 06:18 AM
