HELP!! With headlight electrical problem!
Old Feb 3, 2005 | 07:23 AM
breyblueyes's Avatar
My pass headlight went out and I figured it was the bulb so I replaced it and it did not fix the problem. After that, I tested to see if any power was getting to the plug on that side and their was but very little. Now the driving lights stopped working and won't come back on. When I turn on the headlights the only thing that comes on is the driver side headlight on low beam. I have no marker lights, no tail lights, the turn signal only flashes on the dash but not outside. Same as on highbeams but both headlights work on highbeam and still don't have any driving lights whatsoever though. I was getting ready to sell this car until this happened! Anyone who may have any expertise that could help would be a freaking lifesaver!! Thank you a thousand times in advance! Jeremy
Old Feb 3, 2005 | 07:56 AM
Wiking's Avatar
All that without smoke?
Check fuses inside, top right. Under hood, beside battery.
Light switch contacts burned; take sw out and clean contacts. Maybe this whole assy burned as it contains also the blink.
Old Feb 4, 2005 | 09:33 PM
Pyrophilus's Avatar
Most likely your turn signal stalk is bad. I had this problem for months (only driver's headlamp, no interior lights, no speedometer lights, no taillamps) fuses and relays (if any for 3rd gen headlamps) were all good. I traced wires from engine bay to steering column to no avail. I then decided to take out the turn signal stalk and open it up. If you do, you'll see that there are ALOT of carbon build-up on the switch contacts. Scrape them off and you should be back in business.
Old Feb 5, 2005 | 07:47 PM
Pyrophilus's Avatar
Internet automart has new turnsignal/headlamp stalks!
If you want to troubleshoot, what I did was to pull the harness off the turnsignal stalk, and used a length of wire to short the 12VDC+ to the lowbeam pins in the wiring harness (there are two, one for left and one for right). If shorting them causes the light to come right on, then your problem is with the turn signal stalk, although I am about 98.5% sure that this is your problem...
Old Feb 6, 2005 | 12:28 AM
ke5adb's Avatar
Headlight switch, around $75 at local Nissan dealer.
Old Feb 6, 2005 | 02:43 AM
Pyrophilus,
Do I have to take the steering wheel off of my car to check out the turn signal stalk ? Thank you for your insite so fat too, it sounds like I might be able to fix it myself hopefully.
Old Feb 6, 2005 | 02:53 AM
Wiking's Avatar
Pyrophilus,
No, just the plastic covers.
Switch connecting points may be mechanically cleaned: if you scratch them, will cause fast contact burn. Use most fine 'sandpaper' that can be found.
Still the repaired one will not last as long as new: add extra relay for main lights to get the current load off from the sw contacts.
Want to see smtg with u lights?
see: http://www.cardomain.com/memberpage/748507/10
knight_yyz
Oct 24, 2015 08:05 AM
Vistance
Sep 17, 2015 05:17 AM
mpbclutch33
Sep 8, 2015 06:21 PM
