Replacing Steering Rack
Old Feb 4, 2005 | 01:24 PM
bal4833's Avatar
I am attempting to replace the steering rack. It puked a bunch of power steering fluid out of the cracked boot when I turned the front wheels to get at the caliper mounting bolts for a brake job. I have 4 of the 5 mounting bolts out. Need help getting the bottom right bolt out. I don't seem to be able to get the right wrench combination to turn the bolt. The only solution I can see is to remove the Y exhaust pipe. Is there another trick? I don't own any of those crowfoot wrenches, but I will go get some if somebody thinks that will allow me to get it off.
Old Feb 4, 2005 | 04:59 PM
avmaldo's Avatar
uhh, should have removed y-pipe. the bolt should come off without to much trouble. When i did it, it was kinda of a PITA but just keep trying.
Old Feb 5, 2005 | 09:40 AM
bal4833's Avatar
Steering Rack Removal
Thanks. I definetly agree with the PITA. I did end up removing the Y pipe. Seperating the quill shaft connection also turned out to be challenging. I have it loose now, just need to figure out how to snake it out the hole. I hope assembly is a lot easier.
Old Feb 5, 2005 | 10:40 AM
goon9's Avatar
I pulled one out of a VE from the driversside wheel well. You have to lift the passenger side of it and on the driverside pull it down and out.
hydriplex
Aug 28, 2015 02:13 PM
tnewbs
Aug 28, 2015 10:15 AM
Mrbizness1
Aug 18, 2015 08:43 PM
Flores94
Aug 11, 2015 12:53 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
