jdm engine
Old Feb 7, 2005 | 01:30 PM
  #41
Jeff92se's Avatar
I'm needing a caw
I agree. But to truely do a NA to turbo setup "right", you should spend some $.
Originally Posted by subs1000w
if both setups are done right with a conservative tune you wont have any reliability problems
Old Feb 7, 2005 | 02:29 PM
  #42
DanNY's Avatar
Ad·min·is·tra·tor
Originally Posted by mtnbikeair
FOR WHAT?!?!!!
Old Feb 7, 2005 | 02:47 PM
  #43
MrGone's Avatar
Originally Posted by DanNY
FOR WHAT?!?!!!
what every other JDM engine is used for...
a paperweight
Old Feb 7, 2005 | 04:18 PM
  #44
5 ltr. beater's Avatar
Originally Posted by mtcookson
i just don't see how cruising with a turbo and low compression could be less reliable than an high compression n/a engine constantly pounding the internals. the combustion chamber pressure of both would be very different when they are both at cruising speeds/throttle. now when at wot i can see the boosted engine being less reliable due to the heat and all that but a daily driven car isn't going to be at wot near as much as a race car.
Who is saying that you're wrong? Your observation is 100% right. I used to think that turbo cars didn't last as long as N/A cars simply because they made more power.
But then my friends explained to me, that turbo or supercharged motors only come onto boost at WOT which is where they make most of their power. So if you're just driving normally, there is nothing to worry about except for the excess heat that after a while, takes it's toll on hoses, wires etc.
On the other hand, if you have a bored and stroked I4 with mad compression, that thing won't last long enough for you to enjoy it; or for word to get around that you actually have a fast car.
Old Feb 7, 2005 | 04:50 PM
  #45
Jeff92se's Avatar
I'm needing a caw
MT and 5ltr. You guys are comparing almost 2 diff things. Subs said you could build 300hp with a VG and turbo. That is very true. But the 300hp na engine is built MUCH stronger. Not because it's na, but because of the stuff they built it with. Now you want to compare putting a turbo on a stock oem na VG to a fully built VG. If you granny both engines, sure they will last. But then again, why even build a na engine or turbo if you are going to granny the thing?
Old Feb 7, 2005 | 05:20 PM
  #46
mtcookson's Avatar
well lets say both engines are equal. same internals except that the boosted engine has low compression pistons and both are pushing 300 hp. it would still seem logical that the boosted engine would tend to last longer as a daily driver since the majority of the time the turbo engine would have less strain on the internals due to the low compression whereas the high comp engine is constantly at the higher compression ratio.
when going wot its a whole other story. with boost there tends to be more pressure in the end which is why most boosted engines create a lot more torque than the n/a engines... because you are basically increasing the displacement by putting more air in than the engine would normally be able to take in. then you also have the immense heat of the turbo system and such.
in that case, the n/a would most likely last a lot longer.
in the end though... all i know is a boosted engine is a lot more fun to drive around than n/a
Old Feb 7, 2005 | 06:05 PM
  #47
Jeff92se's Avatar
I'm needing a caw
But they aren't the same.
Old Feb 7, 2005 | 06:09 PM
  #48
mtcookson's Avatar
lol, yeah i guess that's true.
Old Feb 7, 2005 | 08:04 PM
  #49
DanNY's Avatar
Ad·min·is·tra·tor
what a bunch of bench racers
Old Feb 7, 2005 | 08:59 PM
  #50
95turbo gxe's Avatar
well I got a 4th gen with intake and cat back. And beat a 5th gen6 speed with intake and jwt ecu, But never raced a 6th gen yet. Oh the 5th gen was an 03 with the 3.5
Old Feb 7, 2005 | 09:15 PM
  #51
subs1000w's Avatar
JWT doesnt make an ECU for the 5th gens
Old Feb 7, 2005 | 09:19 PM
  #52
Oh ok Maybe im wrong. I assume it was jwt but It may be jet chips. But he has something because it dont redline till 7200rpms.
Old Feb 8, 2005 | 01:15 PM
  #53
......and they don't make them for 4th GEN's either thank god. Otherwise, VQ's would be more of a problem than they are now. (not for me though!)
Old Feb 8, 2005 | 01:17 PM
  #54
Jeff92se's Avatar
I'm needing a caw
JWT DOES make ecus for the early 4 gen.
Strike TWO!
Old Feb 8, 2005 | 02:55 PM
  #55
jwmaxse's Avatar
Why aren't VQ's a problem for you, did you go out and buy an electric supercharger or something?
Old Feb 8, 2005 | 03:14 PM
  #56
MrGone's Avatar
Where is my answer
Old Feb 8, 2005 | 04:13 PM
  #57
Strike TWO!
Ok.......if you're going to be exact.....they make them for the 95 only. But a LOT more than that were produced after 95. So overall it's safe to say THEY DON'T MAKE THEM. A one year production of one model compared to four other years of another is enough to make that claim. Jeez.......do we always have to be exact?
And as far as that hekimian racing engines goes. I know he made a racing VE motor. I'm going to call him tomarrow. I remember printing out the page of specs that the motor came with. I even spoke with the guy over the phone a while back. So don't be in such a rush to call a strike on that one either. I just haven't had any time lately to call (work,school, taking pics. of ECU's for Aaron..etc.etc.)
Old Feb 8, 2005 | 04:18 PM
  #58
Jeff92se's Avatar
I'm needing a caw
I'm just giving you a hard time. But JWT does make them for I think the pre-97 4-gens. That's alot of 4-gens. If Hekimian Racing did indeed make a built VE30DE motor, I'd like to know everything about it. But I would have thought it would make more than 20hp vs the built VG30 engine they have on their site. Make sure to ask them about the ecu tweaks.
Old Feb 8, 2005 | 04:27 PM
  #59
I haven't been beaten by a VQ yet. The closest race i had with a VQ max. was a 99 5 spd. and it had a CAI, pulley and catback. I won, but dam they are fast.
But, were all destined to loose sometime; and it's only a matter of time before i get mine handed to me by a Max on the bottle!
Old Feb 8, 2005 | 04:41 PM
  #60
When I was selling Stillen parts on the org. a while back. One guy had asked if he could get a JWT ECU for his 96 max. I said no problem. But when I called stillen, to get a quote, james in the sport car section, informed me that JWT doesn't make performance ECU's for that year or any other above that. He said the reason being was because JWT has not craked the OBDII code yet and they apparently were in no hurry to do so.
And yeah, as far as that VE motor went, I swear that back in the day, it was listed on his website (8 years ago) I don't remember much, but I do remember that it was a bored out VE from 3.0 to 3.2 and it had an 11:1 comp. . I need to call him a.s.a.p. to find out what happened.
Old Feb 8, 2005 | 04:44 PM
  #61
Jeff92se's Avatar
I'm needing a caw
From what all the 4-gen guys are saying, all 4-gens were OBDII. I tend to believe that as even 1995 year maximas are using the obdII scan tools on thier cars. Now I'd be very happy to find out that they were using obdII scan tools for their OBD1 ecus. Because that would mean I could use the auterra for my car. But I very much doubt that is the case as we all know all 3-gens are OBD1.
It really makes sense that Nissan knew of the OBDII requirement and got ready for it when the all new VQ30/4-gen came out.
Old Feb 8, 2005 | 04:49 PM
  #62
word! I wonder why they make them for th 95 though.
Old Feb 8, 2005 | 06:28 PM
  #63
jwmaxse's Avatar
I have a 95 and it's OBDII, I would say without a doubt that there's not any OBD1 VQ maxima's running around there.
BTW: 5 ltr. beater, what does your maxima run in the 1/4 mile? Which maxima are you driving? I know your profile says you sold the '92 and still have a '94 auto.
Old Feb 8, 2005 | 07:03 PM
  #64
MrGone's Avatar
There is no such thing as a OBD-I 4th gen.
From my small ammount of reading I believe only the 99-present maximas do not have JWT ECU's avaliable to them. I am not sure about 2nd gen maximas.
Old Feb 8, 2005 | 08:00 PM
  #65
Scope's Avatar
Im izz sexay
Is there a way to convert to OBDII or I have to wait for the Zemulator (if it's produced for the VG)
Old Feb 8, 2005 | 08:55 PM
  #66
subs1000w's Avatar
man guys seriously if you all would just go to JWTs site and check.
jeff your right JWT only makes ECUS for 95-96 4th gens
mr gone your right in a sense because the 97-98 4th gens can use a 95-96 jwt ecu but get a CEL which i belive can be defeated somehow
99's and 00-01 are screwed
02-03 and 95-96 can get a technosqaure ecu for 495$
Old Feb 8, 2005 | 08:59 PM
  #67
subs1000w's Avatar
unless your IQ is above 200 youll have to wait for the ZEM just like all the rest of us
Old Feb 8, 2005 | 09:06 PM
  #68
505max94se's Avatar
Are you sure about that?
Why do you think JWT only makes them for the 95-96 maxima?
Old Feb 8, 2005 | 10:16 PM
  #69
MrGone's Avatar
unless a local guy has a 95-96 ECU in his 97. I was pretty certian they reprogramed the 95-98, with the 95-96 being slightly different than the 97-98 (I believe mainly because of the digital odo).
Then again I dont spend any time in the 4th gen forum.
I am however 100% positive about the OBD-II
Old Feb 8, 2005 | 10:25 PM
  #70
505max94se's Avatar
I thought all cars before 96 or 97 (i'm not sure) were OBD-I. I'm sure your right and I don't know too much about 4th gens either.
Old Feb 8, 2005 | 10:29 PM
  #71
MrGone's Avatar
1996 was the first year it was federally required to have OBD-II on any new cars being sold. However a few manufactures equipped their vechicles with OBD-II eariler.
Old Feb 8, 2005 | 11:07 PM
  #72
Jeff92se's Avatar
I'm needing a caw
Are my posts somehow invisible?
Old Feb 8, 2005 | 11:12 PM
  #73
Zack342's Avatar
not invisible. Just ignored... Also it was mention that 00-01 guys can't get an ECU upgrade...Technosquare can do 01 ECu's. 95-96 are the ECU's that JWT and Technosquare do but they can be used in 97 and 98 cars. with CEL and on 98 slight Modification
Old Feb 8, 2005 | 11:24 PM
  #74
505max94se's Avatar
No I'm just going blind
I can't believe I didn't see that.
I was once told by some one that all cars after 1996 were OBD-II and I just ASSUMED that pre-96 cars were OBD-I. All that assuming only made an **** out of me. I couldn't remember if they told me '96 or '97 though.
Now that's all cleared up....
Old Feb 8, 2005 | 11:40 PM
  #75
jwmaxse's Avatar
'95 was a transitional year for OBD-II on alot of vehicles. I have a '95 200sx that's OBD-II and as mentioned before my '95 maxima is OBD-II. Like Mr.Gone said, it was required in '96 to have OBD-II but some cars started sooner.
Old Feb 9, 2005 | 07:36 PM
  #76
Yes there is. 95 maximas were put into production in early 94. In 95 the law was put out that all 1996 vehicles sold in the US had to be OBDII compliant. Nissan left alone the 95's and began putting OBDII on the 96's. Thats why on JWT's website, they have JWT ECU's only for the 95 Max. Not sure if it will work on a 96' even though the website says it will.
Old Feb 9, 2005 | 08:05 PM
  #77
subs1000w's Avatar
read this thread and if you still feel there are OBDI 4th gens do us all a favor and go jump off a cliff
http://forums.maxima.org/showthread.php?t=277214
Old Feb 9, 2005 | 08:45 PM
  #78
505max94se's Avatar
I can't believe this was brought up right after it had been discussed.
Old Feb 9, 2005 | 08:49 PM
  #79
jwmaxse's Avatar
Old Feb 9, 2005 | 08:53 PM
  #80
oh well, I could've sworn there are OBDI 4th GEN. max's rolling around. But 3 against 1 says there isn't. I wonder way they offer JWT ECU's for the 95 only though.
