Eh, sparkplugs
Old Feb 5, 2005 | 05:15 PM
mtnbikeair's Avatar
Eh, sparkplugs
Okay, so i had some extra time, actually i always do, but i decided to see what my spark plugs look like because i saw that chart on the back of the Haynes repair book, and the end to my spark plug is white. And the book said that my car might be running to hot. Anyone have any ideas, or things i could check, i can also post a picture of my spark plug if that will help people.
Old Feb 5, 2005 | 05:21 PM
internetautomar's Avatar
mod or sell?
Old Feb 5, 2005 | 05:23 PM
HTPerformance's Avatar
Post It!!!
Old Feb 5, 2005 | 05:31 PM
mtnbikeair's Avatar
Old Feb 5, 2005 | 05:45 PM
mtnbikeair's Avatar
so any ideas?
Old Feb 5, 2005 | 05:52 PM
MrGone's Avatar
Ngk Bkr5e-11
Old Feb 5, 2005 | 05:53 PM
mtnbikeair's Avatar
whats that mean?
Old Feb 5, 2005 | 05:57 PM
MrGone's Avatar
NGK is the brand
BKR5E-11 is the plug number
They are the copper version of the platinum plugs for our cars. You can buy the Platinums if you want but it's extra money, I figured since you already had copper you would probably just stick with them.
edit: do'h your a VGer anyway lol. Just stick with the coppers.. IE. the number I list above
Old Feb 5, 2005 | 05:58 PM
maximagxe90's Avatar
hi,
looks like you got carbon build inside the engine,
Old Feb 5, 2005 | 05:59 PM
mtnbikeair's Avatar
But whats causing the white stuff? Is that just normal and its time for me to replace them, or is my car upset with me and its trying to tell me something?
Old Feb 5, 2005 | 06:21 PM
MrGone's Avatar
That's at about 6000 miles, maybe 8000. I dont remember If I changed them at 125k or 127k but either way I just pulled that 5 mins ago and took the pic
Old Feb 5, 2005 | 06:33 PM
mtnbikeair's Avatar
yeah mine have been in for about 10000 miles i think
Old Feb 5, 2005 | 06:45 PM
mtcookson's Avatar
by the looks of it its running lean/hot like you said. what grade fuel do you usually use?
also, shawn... isn't that number for 1 step hotter plug? (i think we discussed this before but i can't remember... )
Old Feb 5, 2005 | 06:48 PM
MrGone's Avatar
yeap, and everytime I say BKR5E-11 you always ask
Right Click
->Set As Wallpaper
Old Feb 5, 2005 | 06:51 PM
mtnbikeair's Avatar
I run whatever regular fuel is, 87 or somethin like that, so if my engine is running hot, i know this is a large question, but what should i check? and is my car in danger from this?
Old Feb 5, 2005 | 07:12 PM
mtcookson's Avatar
ahhh, ok... let see if i can burn that image into my memory or something
so i guess technically i have two steps colder... i guess...
as for the fuel and such, you might try running 89 and seeing if the plugs even out at all. i know when my other maxima was ran on 87 it ran like crap... not sure if it was just crappy gas or what but ecu must've registered some pinging because it felt slower than hell (and no... that's not because its a auto vg dammit! )
Old Feb 5, 2005 | 07:38 PM
mtnbikeair's Avatar
So i'll try the gas, anything else that could cause this white stuff?
Old Feb 5, 2005 | 08:44 PM
mtcookson's Avatar
injectors could be an issue if they aren't clean, limiting the fuel going in.
another issue could be unmetered air going into the engine. might check for hose leaks that are after the maf. other than that i'm not really sure what else could do it except for boost.
Old Feb 6, 2005 | 01:05 AM
Wiking's Avatar
gOOGLE the issue: "white spark plugs..."
First example: http://www.ngksparkplugs.com/techinf...q/faqread2.asp
http://www.bullittarchive.com/Mainte...g_Spark_Plugs/
http://www.strappe.com/plugs.html
etcetc
Old Feb 6, 2005 | 11:50 AM
Bman's Avatar
Not sure what causes hot combustion chamber temps off the top of my head, but do you use a lot of (additional) fuel additives or cleaners? I don't remember what colour that comes out to be, but apparently frequent use of those things sometimes shows up on the plugs as deposits.
I'd get a service manual and look at the emissions controls, as I think those may be related to this kind of problem.
Old Feb 6, 2005 | 12:04 PM
mtcookson's Avatar
usually white plugs means running lean... which causes high combustion chamber temperatures.
Old Feb 6, 2005 | 02:49 PM
mtnbikeair's Avatar
I replaced my spark plugs today with some new bosch ones, and i got my timing set up where it should be, and i tell you what, i have never known my car to run this quick or smooth. Im very happy.
Old Feb 6, 2005 | 03:07 PM
mtcookson's Avatar
actually.... don't go with bosch.
they have been known to not do too good on these cars as well as many imports. you really want to stick with ngk.
Old Feb 6, 2005 | 03:11 PM
MrGone's Avatar
Ngk Bkr5e-11
READ!!!
Old Feb 6, 2005 | 03:23 PM
mtnbikeair's Avatar
Yeah, its all autozone had tho, you gotta work with whats available.
Old Feb 6, 2005 | 03:41 PM
lalo's Avatar
Wait a few days, RPMS will start jumping and you will wish you had listened to mrgone
Old Feb 6, 2005 | 03:54 PM
mod or sell?
Find a real store that knows what the car needs.
not that joke that they call autozone
Old Feb 6, 2005 | 03:55 PM
mtnbikeair's Avatar
Oh, im not doubting Mrgone, i will get those spark plugs next time i need some, or when mine crap out, but i needed spark plugs today to get my car running and i had to work with what was available.
Old Feb 6, 2005 | 08:56 PM
Hi,
if you have bosch in your engine,
when your engine is at normal running condition it will start to bog down and run slow,
i would suggest you to stick with ngk your engine will run better and respond better,
i tried bosch in my engine before and my engine did not respond that will and lose a lot of power,
so don't use bosch and stay with ngk,
bosch sparkplugs are made by german and they are crap,
Old Mar 29, 2005 | 02:45 PM
Jeff92se's Avatar
I'm needing a caw
Why run the one step hotter plugs?
Old Mar 29, 2005 | 03:55 PM
92SE_Dave's Avatar
It was probably the timing that really helped. Retarded timing and low octance gas make your motor run real hot.
Old Mar 29, 2005 | 04:22 PM
mtnbikeair's Avatar
Well actually after all that, i was going to check the compression all my cylinders, and when i had to take the spark plugs out to do it, they were white again already. So who knows, but i guess it doesnt matter because that car is for sale now. So on to a new project that is even bigger.
bumpypickle
Sep 20, 2015 08:22 AM
rhonster
Sep 19, 2015 04:29 PM
Tha'-Max
Aug 30, 2015 01:14 AM
MyMax92
Apr 5, 2002 12:22 AM
