Help!!!!!!
Old Feb 9, 2005 | 11:57 AM
505max94se's Avatar
Help!!!!!!
What is the name of the oil seal that is directly behind the crankshaft pulley? Part stores tell me that it's the timing cover seal but, I think it's the front crank seal.
Old Feb 9, 2005 | 12:05 PM
DanNY's Avatar
Ad·min·is·tra·tor
yup you're right...best bet is to buy it from the dealer.
Old Feb 9, 2005 | 12:19 PM
«§»Craig B«§»'s Avatar
Read the stickies!!!!! UDP install article even gives you the correct part number
Old Feb 9, 2005 | 02:07 PM
internetautomar's Avatar
mod or sell?
actually the parts man is correct for a change.
when the aftermarket is referring to a crank seal they are referring to the rear main seal.
The front seal is called a timing cover seal whether or not the seal actually goes into a timing cover.
Old Feb 9, 2005 | 02:11 PM
Jeff92se's Avatar
I'm needing a caw
Unfortunately they still often give you the wrong part. We went though this I think.
I went round and round with Napa trying to get the right seal. They had a very hard time finding it. I ended up with the wrong seal. The VE30DE is a hard engine to get the correct parts for.
Just to go a Nissan dealer. I even went to a local Nissan dealer that's not really known to give discounts and their price was about the same as any aftermarket one. Plus they usually had it in stock.
Old Feb 9, 2005 | 02:15 PM
mod or sell?
I was only referring to part description, not neccessarily part #.
Old Feb 9, 2005 | 02:55 PM
Dj Paul's Avatar
read craigs how to page it tells you part number and name
Old Feb 9, 2005 | 08:27 PM
505max94se's Avatar
Craig's "how to" page has no information on the udp. The only write-up that I know of is on 4dsc.com in the articles section and the only description it has is "oil seal."
The part man is wrong in this case but, the description is correct on your site.
I went to napa and bought the "timing cover seal". When I went home to install it, I figured out that the new seal was the same as the old seal accept it was slightly too small. So I went back to napa and they started to give me another "timing cover seal" accept this one was totally different. I thought i napa didn't have it then most likely the parts stores wouldn't either but I decided to go to auto zone and pep boys anyways. As I thought they didn't have it either. Finally I called the dealer and asked if they had the "front crank seal" and the said that they had it in stock. I went down there and bought it. The part number is 13510-97E10 and it cost $5.95 plus tax.
Old Feb 9, 2005 | 10:34 PM
Jeff92se's Avatar
I'm needing a caw
Again, my posts must be invisible to 505max94se.
Old Feb 9, 2005 | 10:49 PM
MrGone's Avatar
[size=3] [b] [color=magenta]
seems to get their attention
Old Feb 9, 2005 | 11:25 PM
Wiking's Avatar
Young, vital growth -speed:
...gRREAT hurry, keep running, NO TIME to jump in/enjoy a ride tHERE...
...or read or listen.
Nohurry anywhere *bangs* in only after two kids... four?
Old Feb 10, 2005 | 12:04 AM
505max94se's Avatar
No, actually I saw it and I didn't feel like quoting it. I just wanted to tell my story.
Old Feb 10, 2005 | 12:07 AM
505max94se's Avatar
Once again, what does v8000 mean?
Old Feb 10, 2005 | 12:12 AM
MrGone's Avatar
http://forums.maxima.org/showpost.ph...1&postcount=31
Mines from Napa, but I also recieved the wrong one the second time I bought it. Then I found my first one and used the money from the VG one for an oil filter
I would have already posted the PN but dont have it
Old Feb 10, 2005 | 12:20 AM
505max94se's Avatar
Now that makes sense.
I have had my udp on for quite a while and it's been leaking because I never replaced that seal. So finally I got around to replacing it.
I'm also filling my motor mounts, replacing my alternator, installing a 4 ch amp, installing some compenents, and installing those washers that are required for the es control arm bushings.
Old Feb 10, 2005 | 01:04 AM
MrGone's Avatar
cool deal
I'm in the middle of installing Koni's, but I decided mid-way though I want to use all new insulators and such so I'm waiting for those to arrive. I just replaced the bushings, balljoints and tie-rod ends on our Durango and after feeling that difference (1998 with 118k and not driven hard at all) I'm going to do it on my car aswell .
Old Feb 10, 2005 | 05:56 AM
That part number is on the 4dsc.com/articles site. If you take 1 minute of your time, you can find the part name by using that number on several different sites or even easier you can call a dealer.
Old Feb 10, 2005 | 12:13 PM
505max94se's Avatar
Why did you if the part number is there.
I was just looking at the install of front crank seal in your write-up to find information on the seal. I've read it in the past and I don't remember seeing the part number. Now that I read it all again, I see that the part number is there. As you can see I already found the part number, name, and the part but thanks anyway.
BTW your write-ups are friggen awesome.
