Anti-lock Brakes Malfunctioning
Old May 1, 2001 | 12:10 PM
GA MAX
About 4 days ago it rained hard in this area. Since that day, the anti-lock brakes on my '89 Max have been malfunctioning.
The anti-lock feature kicks in when I come to a stop and when I'm traveling under 5 miles an hour. What happens is that I press on the brake and just before the car comes to a stop, the anti-lock kicks in and releases the grip of the front calipers. It also makes a funny sqeak sound as it malfunctions.
I don't know why this is happening at very slow speeds and under totally dry conditions. Does anybody know what's wrong? Thanks.
Old May 1, 2001 | 03:23 PM
Brandon90gxe's Avatar
hmm... you sure you got abs? i didnt think they had it till 91? ...
Old May 1, 2001 | 05:53 PM
90maxSE's Avatar
yea i am sure he does...
i have a 90se and it has them, i think only the se's had them, and few of them becasue it was an expensive option
Old May 1, 2001 | 06:05 PM
brubenstein's Avatar
According to the FSM:
1 - check for foreign material and clearance of the sensors at the wheel (0.008 - 0.039 in)
2 - Proper grounding (0 ohms) of the sensor wire shields (on strut towers).
Old May 1, 2001 | 06:43 PM
FroMan's Avatar
considering that it is a saftly equipment failure you should take it to the dealer for trouble shooting and repair.
Fro
Old May 1, 2001 | 10:01 PM
Czar's Avatar
I betcha anything that either your left or right front wheel speed sensor has bit the dust. Somehow water gets in there and corrodes the wires. To be sure, measure the resistance of the two sensors at the harness connector on the strut tower inside the engine compartment. If you can't get continuity between .8 -1.2 K ohms, you got a bad sensor. Has happened to me and others on this board.
Old May 1, 2001 | 10:38 PM
GA MAX
Speed Sensors
Thanks for the tip... Any idea as to how much a new sensor would be and are they difficult to replace? Thanks again.
Old May 1, 2001 | 11:23 PM
Czar's Avatar
From a dealer 350+, from courtesy 250+, from a junkyard 20+... Takes maybe a half hour max.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
