Perfomance Mod Or NOT?
Old Feb 20, 2005 | 04:54 PM
Alon26's Avatar
Just wondering if anyone knows anything about these So-Called Performance Chips???
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
Old Feb 20, 2005 | 05:03 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
Old Feb 20, 2005 | 05:59 PM
MrGone's Avatar
pass
Old Feb 20, 2005 | 06:22 PM
Loe max's Avatar
Originally Posted by MrGone
pass
gas
Old Feb 20, 2005 | 08:02 PM
ozzombie13's Avatar
I will eat your children
i would never trust any of those things. like the tornado and othes all worthless. dont waste your money
Old Feb 20, 2005 | 08:30 PM
Matt93SE's Avatar
STFU n00b!
it's a freaking resistor man.. do you HONESTLY think you can gain power from $7?
Old Feb 20, 2005 | 09:58 PM
garbury's Avatar
I did....I was even dumber and bought a 30 dollar one thinking it was "special", theres a meager performance (like none) increase and a very small change in sound. I wouldn't buy one for my new max, it is a waste and the people who sell them should burn.
Old Feb 20, 2005 | 10:24 PM
Matt93SE's Avatar
STFU n00b!
they're simply making money off the stupid.
when are people going to realize you're not going to "unleash the power" for a mere $10.....
Power costs money. how rich are you?
Old Feb 20, 2005 | 11:31 PM
garbury's Avatar
I know, that was a year ago and i have since gotten wiser. Better than wasting money on one of those marine pump "supercharger kits" though.
Old Feb 21, 2005 | 12:38 AM
Wiking's Avatar
...well, with 10$ u get a drill bit, right?
Std stock air inlets are normally choked beacuse of noise & low end torq. I u care more of pwr, just drill filterbox to get significant boost. How big it is, depends on the vehicle characteristics:
see: http://www.cardomain.com/memberpage/748507/2
Old Feb 21, 2005 | 06:32 AM
Matt93SE's Avatar
STFU n00b!
that'll gain you a couple, but the best way to gain power from an intake is to remove it and replace with a better cone filter and a properly designed intake tube.
Old Feb 21, 2005 | 07:40 AM
Wiking's Avatar
Still, cheape$t way to kick the idle horses onto arena. Better intake tube yess, but until dyno proven, my opinion is that cone will get but few rabbits more. The filter model e.g. flow capacity defines more. FRAM seems [just opinion] to be better than Nissan original flow (in the stock class).
Old Feb 21, 2005 | 07:57 AM
Cliff Clavin's Avatar
Way out West
getting cold air (and more of it), along with a better flowing exhaust is dyno proven to get more hp.
Matt93SE's Avatar
STFU n00b!
well sure... if you're keeping the tiny stock sized filter element in place... there's some testing out there somewhere on various paper filter elements on a Miata.. may be worth looking at.
Old Feb 21, 2005 | 08:17 AM
MrGone's Avatar
you really dont gain too much with filters, I noticed the most gains when I messed with the mid-pipe. The rest of the crap I didn't notice much of anything (except noise).
Old Feb 21, 2005 | 08:49 AM
Wiking's Avatar
I get cold air always for my horses as I drive. No need of dynohorses which work only in stationary stable...
It may be so that at launch lower input suction pipe might have some% gain, dunno, no REAL life tests done. At least not presented to me.
Next time u are on track, do test with/without the pipe extension to get some data.
Better filter is always better, and does make a real difference. Diesel does not care too much... Only airflow counts, not color.
Note: I am not saying that the best tubings (few are) with higher capacity filter and lower intake is not better, surely is. But how much? I dare to suspect that not much...
But compared to the price of holes, no way mister anythin work$ better.
(The lower your air input is, the more ofthen u need to change filters. Does not matter too much, though)
Dear sirs, u are rich: have all the widgets, dynos and u do go racing: test and give us the numbers. After multiple vehicle tests with same air intake elements, as u provide data here, I will shut up
...edit: besides, u see in the pic that I get better cooling for my autotranny resistor.
Old Feb 21, 2005 | 09:00 AM
disgruntled's Avatar
I'm thinking if you can add a fan or motor of some sort just before the filter to create a vacuum force that will suck in more air, no matter how slow/fast you are driving. I was even going along the line of rigging up a portable air pump/presssurizer(the cheap, fix a flat pump that will plug into your cig lighter) that will continously introduces air into the intake with and modding the air ducts to blow AC air directly at the tank, and once the metal casing gets cold, the air will be slightly cooler (helps on a summer day). Don't know if it will work, just putting my idea out there. Please gimme some input, and flame away if you guys think its stupid.
Old Feb 21, 2005 | 09:13 AM
Wiking's Avatar
No flame, just figuring out the the video: the BMW behind u will get a surprise hole in winshield as that propeller bits shoots outta maxima exhaust pipe. This is the result of your horses sucking that tiny winy propeller and all attachment screws into engine...
The airspeed at full throttle nears sound speed. No way to hlp it with fans. And with that speed, the air has no time cool or warm in the 'tunnels': needs a real big cooler with a lot of cooling surface area. Btw. That cooler could help even without turbo...
Old Feb 21, 2005 | 09:32 AM
Hmm, didn't think of THAT scenerio, but if the induction force is that great, then screw the fan in the tunnel idea. So now the only idea that remains afloat is introducing massive air right to the filter, or maybe adding one of those electric cool thing(thermoelectric cooler) attached to the air compressor tank, hell, I can line up the whole intake tube up to the filter box with these things and basically have a cooling tunnel.
Works better with a mandrel bent aluminum tube (i.e. CAI without the set up)
Old Feb 21, 2005 | 09:58 AM
Wiking's Avatar
...maybe ? exxaggerated a SMALL bit. The suction force is not that bad. But the volume needed at full throttle, is no business for fans: visualizing how/ why the fan takes 120.000rpm - oh boy... check why/how turbos are built...
Somebody sells these fanny '69$ turbos' on the net. Should be jailed...
I have sometimes thought that (?) compressed air tank: u need lots of air just for six ? seconds... take a tank, small compressor, then release all at once. Would that freeze tha whole intake solid???
Edit: Btw. The current intake is heavily wrmed via cooling liquid. Try choking that flow off first. (Not idle intake flap flow)
Old Feb 21, 2005 | 10:05 AM
I was going along the line of regulating the released air at about 5 cfm or more, as the steady resupply/discharge of the air compressor will also serve to cool the tank down since constantly moving air = cooler surroundoings. That + the thermoelectric coolers on the intake tube should cool the air down to a couple of degrees. Since colder air contains more O2 (more condensed), it will help with the fuel burning ratio of the car in the summer, and just shut the whole thing off in the winter unless you want to super freeze the thing. The compressor will not overload, since it will be able to have intermittent off time, allowing it to rest. How does that sound?
Old Feb 21, 2005 | 10:46 AM
Jeff92se's Avatar
I'm needing a caw
Not to mention the guy is stealing a picture right off of overboost (even has their logo) Oh well, live and learn
lrb6805
Sep 30, 2015 08:12 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
