several problems, studdering, need help
Old Feb 22, 2005 | 05:36 AM
Konamonkey02's Avatar
92 max GXE w/ the VG is studdering at lower speeds and then smooths at higher speeds(55ish).... its begining to studder at the higher speeds now too, the belts are pretty squeaky as well. There is also a vibrating when the car is idling at rest in drive and park... vibration isnt there in neutral. Is the studdering a timing belt issue? or would it be something like the distributor or fuel pump? also would the vibration be due to engine/tranny mounts or is could it be a worn tranny. I know its alot of questions, any help would be greatly appriciated. Thanks!
Old Feb 22, 2005 | 07:12 AM
internetautomar's Avatar
mod or sell?
injectors
Old Feb 22, 2005 | 11:38 AM
are you sure?
Old Feb 22, 2005 | 12:22 PM
mod or sell?
I can't be 100% sure without doing a bunch of tests.
but that is a likely suspect
Old Feb 22, 2005 | 04:18 PM
hmmm it seems odd for them to just die all of a sudden.... it litterally happend while i was driving.... i was at a stop and i went from stop pretty quick to merge into traffic and it started to do that after i made that turn, so i dunno why it would be an injector. The belts have been squeeking really badly, and since it i just aquired the car, idk if the belts have been changed, all belts are gunna be replaced this weekend to see if thats the problem. Do you think its the injectors going bad or getting clogged. Should i SeaFoam the fuel system?
Thank you very much for your help
Old Feb 22, 2005 | 04:45 PM
mod or sell?
start fixing the problems you know, tackle the other possibilities
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
