Hesitation Problems on a 92 Max
Old May 2, 2001 | 07:12 PM
RitalinBoy's Avatar
Its bone stock and I have had it for a while now. About 109k. Im not sure if it had its 60k tune up, but anyway. This is the problem that I keep having, I have posted before with no luck, perhaps someone can help now?
When I drive the car hard for a short ammount of time and then return to normal driving and then try to drive hard again it seems to have a hesitaion problem around 3k RPM and above. It seems almost to stutter. If I get out and unscrew the gas cap or let the car sit for a while, it returns to its usual punchy self. When I unscrew the gas cap there is a good amount of pressure coming out of the tank, not sure if this is normal or not on the Max. Someone said that I need new spark plugs and wires, would this help? Also, I will be having an oil change done on Friday, what/if anything, should I have worked on to increse performance with out buying new parts?
Thanks for any help,
Jay
Old May 2, 2001 | 07:25 PM
Maximus1000's Avatar
I had a similar problem with my 92 SE not too long ago. After I drove it around for a while and got on it a few times it would hesistate noticeably and have trouble accelerating to about 3500 rpm but once past there it would take off. When I shut the car off and restarted it would be fine. I had the EGR valve replaced as well as the O2 sensor. This instantly fixed the problem. From what I understand the EGR valve wasnt releasing the proper exhaust flow and that coupled with a failing 02 sensor made the car run really lean or really rich (I cant recall which). I hope this helps. Have them run a computer diagnostic first to see if this would help.
Old May 2, 2001 | 07:37 PM
RitalinBoy's Avatar
How much did it cost for you to have both of them replaced? I want to get my baby running so I can race against my buddies 1994 Eagle Talon TSi.
Jay
Old May 2, 2001 | 07:39 PM
BlackMaxGoddess's Avatar
Yeah...what about that?
My 94 max always has a ton of pressure released when I open her gas tank up. Does anyone know if that is normal? I don't remember ever hearing that on other cars. Thanks! ~Christie
matts95max
Apr 23, 2025 10:44 AM
pktaske
May 6, 2016 07:49 AM
MaxLife17
Sep 8, 2015 02:36 PM
pktaske
Sep 4, 2015 08:40 AM
trungg86
Sep 4, 2015 04:58 AM
